11-19-2015 10:47 PM - edited 03-17-2019 04:58 AM
Dears,
I want to block off-net to off net transfer, on configuring " settings the block offnet to offnet transfer service parameter " my internal transfer also is affected ( i mean to say that user A calling gsm-user and if gsm-user want to speak to user B in the corporate user A cannot transfer call internally to user B, )
"i have not configured configuring transfer capabilities by using call classification," it is default to off-net and that should be actually,, if suppose i change to ON-net it will affect the external calling.?????
how i can restrict only external call without affecting internal transfer. i referring to the below cisco document.
You can set two service parameters for the external call transfer restrictions feature: Call Classification and Block OffNet to OffNet Transfer. The following sections provide configuration information:
•Configuring Transfer Capabilities by Using Call Classification Service Parameter
•Setting the Block OffNet to OffNet Transfer Service Parameter
To configure all gateways or trunks in the Cisco Unified Communications Manager cluster to be OffNet (external) or OnNet (internal), perform the following two steps:
1. Using the Cisco Unified Communications Manager clusterwide service parameter Call Classification, choose either OffNet or OnNet (the default specifies OffNet).
2. In the Call Classification field on the Gateway Configuration and Trunk Configuration windows, configure each gateway and trunk to Use System Default (this reads the setting in the Call Classification service parameter and uses that setting for the gateway and trunk).
Additional Information
See the "Related Topics" section.
The Cisco Unified Communications Manager clusterwide service parameter Block OffNet to OffNet Transfer allows administrators to prevent users from transferring external calls to another external number. This parameter specifies values as True or False. Setting the parameter to True blocks external calls from being transferred to another external device. The default value specifies False. You modify the Block OffNet to OffNet Transfer service parameter by using the Service Parameters Configuration window.
When a user tries to transfer a call on an OffNet gateway or trunk when the service parameter Block OffNet to OffNet Transfer is set to True, a message displays on the user phone to indicate that the call cannot be transferred.
Solved! Go to Solution.
11-21-2015 06:50 AM
ok.
As soon as, if A calls B, then A is able to transfer to C ... but ... if A calls GSM, then A's Transfer button is 'greyed out' ... then:
1) How do you access your GSM? It's a H.323 GW, MGCP, SIP Trunk, ...?
2) Check the following:
- A's Device Pool (System > Device Pool), and take note of the MRG List.
- Check the MRG List (Media Resources > Media Resource Group List) and take note of the MRG.
- Check the MRG (Media Resources > Media Resource Group) and take note of the resources used.
- What kind of resources do you have? MTP, MoH, XCode, ...? Are they all "up"?
Hope this helps.
11-22-2015 11:34 PM
That's true, its a global setting, it will apply to all users or none of them.
Manish
- Do rate helpful posts -
11-20-2015 01:38 AM
if you attempt to transfer an external call to a PSTN number or an internal extension , are you getting the exact message on the phone for both scenarios?
Manish
11-20-2015 04:20 AM
Dear Manish,
I applied only 1 procedure.
and i there is no message appearing on the phone,
11-20-2015 04:06 PM
first of all ... if A calls B, then A is able to transfer to C (where A, B and C are IP Phones)?
Second ... A calls GSM, and click the Transfer button ... are you able to dial the B's DN? If the answer is Yes, then B's IP Phone rings?
11-21-2015 06:02 AM
Dear Marcelo,
i cannot dial B's DN the tranfer button is greyed out.
11-21-2015 06:50 AM
ok.
Hope this helps.
11-22-2015 10:34 AM
Dear Marcelo,
things are working normal i dont know i did the same changes before as per the link below before they were not woerking but now it is working only follwoing one below scenario.
11-22-2015 07:37 PM
Dears
The block off-net to off-net is applying to all the users is it possible to exclude the manager from transfer to external calls.
thanks
11-22-2015 07:50 PM
This is a clusterwide setting, so it will apply to all users.
Manish
11-22-2015 11:29 PM
thanks for reply
so you conforming that it cannot be exclude for the specific users.
thanks
11-22-2015 11:34 PM
Manish
11-23-2015 12:24 AM
+5 to you manish
