930
yakubpangat
Beginner
Transfer to Mobile number, the PSTN Trunk is not disconnecting
Customer called and said they can transfer an external calls to mobile number.But this 2 PSTN line is not disconnecting after disconneting this 2 end user.  But direct transfer working fine.
External caller Mr. A (PSTN) ———— > Ext 114 —— > Hold —->  dial mobile number —- > Speaks to mobile caller —– > Hit transfer  Key —— > Call transferd to mobile-----> Mr. A and Mobile user Disconnected the call. But this two PSTN (FXO Port) is not disconnecting.
SH telephony Service
telephony-service
pin 7863
max-ephones 58
max-dn 300 10.10.10.10 port 2000
service phone webAccess 0
service dnis dir-lookup
timeouts ringing 25
url directories http://local/localdirectory
url services http://local/voiceview/common/login.do
url authentication http://local/CCMCIP/authenticate.asp
cnf-file location flash:
load 7916-12 B016-1-0-4.SBN
load 7916-24 B016-1-0-4.SBN
load 7911 SCCP11.9-1-1SR1S.loads
load 7942 SCCP42.9-1-1SR1S.loads
load 7965 SCCP45.9-1-1SR1S.loads
load 7975 SCCP75.9-1-1SR1S.loads
load ata ATA030204SCCP090202A.zup
time-zone 31
date-format dd-mm-yy
voicemail 3099
max-conferences 8 gain -6
call-forward pattern .T
multicast moh 239.100.1.1 port 2000
dn-webedit
time-webedit
transfer-system full-consult
transfer-pattern .T
transfer-pattern 0091T
secondary-dialtone 9
login timeout 1 clear 23:00
after-hours block pattern 1 900
after-hours block pattern 2 901.......
after-hours block pattern 3 902.......
after-hours block pattern 4 903.......
after-hours block pattern 5 904.......
after-hours block pattern 6 905.......
after-hours block pattern 7 906.......
after-hours block pattern 8 907.......
after-hours block pattern 9 908.......
after-hours block pattern 10 00T
after-hours day Sun 07:00 07:00
after-hours day Mon 07:00 07:00
after-hours day Tue 07:00 07:00
after-hours day Wed 07:00 07:00
after-hours day Thu 07:00 07:00
after-hours day Fri 07:00 07:00
after-hours day Sat 07:00 07:00
after-hours override-code 7860
after-hours pstn-prefix 1 9
create cnf-files version-stamp 7960 Sep 20 2012 14:53:05
I hope your valuablie help.
8 REPLIES 8
chrysostomos1980
Contributor
We need voice port configuration
check the below link
http://www.cisco.com/en/US/tech/tk652/tk653/technologies_tech_note09186a00800ae2d1.shtml#topic4
Under global config
#voice class custom-cptone mytone
dualtone busy
  frequency 425 425
  cadence 500 500
dualtone ringback
  frequency 425 425
  cadence 1000 4000
dualtone reorder
  frequency 425 425
  cadence 250 250
dualtone out-of-service
  frequency 425 425
  cadence 320 320
note that all frequency and cadence must meet your pstn provider standards
then call this custom-cptone to all voice-port
#voice-port 0/0/0
supervisory custom-cptone **mytone** ((You need to configure the exact tones for disconnect supervision to work.
Please rate all useful posts Regards Chrysostomos ""The Most Successful People Are Those Who Are Good At Plan B""
Thank you for your prompt replay.
voice-port 0/3/1
cptone BE
timeouts interdigit 5
timeouts wait-release 1
connection plar opx 3089
impedance complex2
caller-id enable
caller-id alerting line-reversal
caller-id alerting dsp-pre-allocate
All voice port are same config
Ok
You need to configure supervisory custom-cptone into the voice ports
Check the link ..The config will be like that but note that all frequency and cadence must meet your pstn provider standards..
Under global config
dualtone busy
  frequency 425 425
  cadence 500 500
dualtone ringback
  frequency 425 425
  cadence 1000 4000
dualtone reorder
  frequency 425 425
  cadence 250 250
  frequency 425 425
  cadence 320 320
#voice-port 0/0/0
I configured the same.
But Still Get the same Issue
In order supervision tones to work you have to config  the exactly tones provider by your PSTN Provider
Somnath Gupta
Could you please capture the PCM capture for a failed call as well as successful, and please attach the same.
Please refer to the following link to collect PCM capture:
https://supportforums.cisco.com/docs/DOC-14060
Apart from the same, please provide us the output of the following debugs:
1. debug voice ccapi inout
2. debug vpm signal
3. debug voip vtsp all
Please do let us know the called and callign numnber.
Please capture the outputs of both failed as well as good call(One that disconnects fine)
Som
Hi friend,
    I here attach all the debug....I hope U can help me
Ex: Mr. A (33534323)-----> Called to CME(423424244)----> from the reception---> Call forwarded to Mr.B's Mobile no.---No A & B is talking.----> they Disconnected the phone---> But still the 2 FXO Port is using.
Dear
            Somnath Gupta
               I hope your valuable replay
Create
Recognize Your Peers
Content for Community-Ad
