08-02-2012 01:22 AM - edited 03-16-2019 12:30 PM
is it possible to use the 7931 IP Phone as a secretary or assistant IP Phone? much like a 7962+7915 extension?
iam trying to find a document to state if the buttons on the right of the 7931 can be used as speed dials, thus to transfer we can:
- pick up call
- press transfer
- press one of the buttons on the right (say button 12 which has extension of needed person to take the call)
- hand up phone to transfer
is the above possible or this is not the case here?
br,
Saeed
Solved! Go to Solution.
08-02-2012 08:09 AM
Hi Saeed,
First off, you are most welcome
On CUCM you could configure button 2-20 for these features. Just build a new
Phone Button template based on the standard (as the default cannot be modified).
For CME;
Cheers!
Rob
"Always movin' ahead and never lookin' back" - Springsteen
08-02-2012 06:47 AM
Hi Saeed,
Are you using CUCM or CME for call control?
If it's CUCM you can add a new Phone Button template for the 7931 that
will allow you to configure that right hand buttons as Speeddials or BLF
Speedials to accomodate your requirements
Cheers!
Rob
08-02-2012 07:48 AM
Hi Rob,
this is a new reqeust and we are pushing for CUCM, we might have to revert to CUCME if needed, but not sure yet.
Form the link i understood that the buttons 13-16 are only able to perform what is needed? is that correct? or any button can be done as such?
thanks again,
Saeed.
08-02-2012 08:09 AM
Hi Saeed,
For CME;
Cheers!
Rob
08-02-2012 08:15 AM
excellent ... great links to read ... ill forward them so we finalize this issue.
thanks
Saeed
