Translating fax calls
Essam Butt
I am using a translation pattern to forward incoming fax calls from PRI1 to PRI2. The scenario is as below:
PRI1>>>H323>>>CUCM>>>H323>>>PRI2>>>FAX
If I send a fax directly to PRI2, the fax is successfuly received without any errors.
But if I send a fax to PRI1, I do receive the fax but with lots of transmission errors.
Do I need to do anything on the GW or CUCM for this to work without any errors??
Thanks in advance,
5 Replies 5
Chris Deren
You need to ensure you are using same fax protocol on all call legs, also ensure there are no errors under "sh controller e1/t1". Are the 2 PRIs on the same GW or separate GWs?  How is your clocking setup.
HTH,
Chris
The same fax protocol is used on all call legs, which is t38 and there are no errors for controller e1.
The 2 PRIs are on different GWs.
Network clocking is configured with controller interface e1.
Below is the printout for sh contorller e1:
E1 0/0/0 is up.
  Applique type is Channelized E1 - balanced
  No alarms detected.
  alarm-trigger is not set
  Version info Firmware: 20100222, FPGA: 13, spm_count = 0
  Framing is NO-CRC4, Line Code is HDB3, Clock Source is Line.
  Data in current interval (346 seconds elapsed):
     0 Line Code Violations, 0 Path Code Violations
     0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
     0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
  Total Data (last 24 hours)
     0 Line Code Violations, 0 Path Code Violations,
     0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
Is it protocol based or NSE based T38? Can you show your applicable configuration?
Chris
Sorry for the late reply.
It's NSE based T38. Below is the configuration for fax:
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
no supplementary-service h225-notify cid-update
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback none
This is not NSE configuration, NSE with H323 would be the following:
fax protocol t38 nse ls-redundancy 0 hs-redundancy 0 fallback cisco
yours is protocol-based, you will need to troubleshoot it with ideally pocket capture or "debug voip rtp session named-event", "debug fax relay t30 all-level-1 "
HTH,
Chris
