09-17-2012 08:42 AM - edited 03-16-2019 01:14 PM
can some one please let me know the defference between translation pattern and transformation patter please.
Thanks.
Solved! Go to Solution.
09-17-2012 09:11 AM
Translation patterns are used for modifying the calling/called party number based on the dialed number. This is done before a destination is selected, meaning calls route through translation patterns to modify the calling/called number before reaching a route pattern which points to a gateway or an end device such as a phone. Transformation patterns are modifying the calling/called party number once an endpoint or destination has been selected. Transformation patterns are used to change the calling/called party number right before a call is sent out of a gateway or trunk, or can be used to change the displayed number on a phone when a call is received.
09-17-2012 09:11 AM
09-17-2012 09:20 AM
Thanks Martini, nice explanation it helped to me understand.
09-24-2013 01:38 PM
Very good explanation. Thanks for taking your time to post it. Please share some Cisco documentation links to understand more about this topic
-Calin
09-24-2013 01:47 PM
Here is the dial plan section of the solution reference network design guide which covers this.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/collab09/dialplan.html#wp1135388
09-24-2013 02:02 PM
Thanks.
-Calin
