I use cucm and mgcp gwI
I want to do a translation on the calling number
extension 3853 calls 0955123456 I hope change calling number to 277773853
calling number 277773853
called number 0955123456
how to do ple help
Hi there,
Check out the following discussion: https://supportforums.cisco.com/thread/2090524?tstart=0
HTH,
Chris
You can apply an external phone number mask of 27777XXXX on the phone line configuration page on the CUCM. Then in the route pattern, check the checkbox which says "Use calling party phone number mask".
Nitesh
PS:Please rate helpful posts
