12-22-2020 04:06 AM
Hello all,
I have a configured a CUCM with Two gateway ISR 4321 with mode H.323.
I have on each Gateway ISR4321 one BRI (line not grouped), i configured the two gateway are fine , on the incoming call work fine each line have their extention , but on the outgoing translation the call start work just by the BRI on the gateway 1.
How can i make outgoing call translation by each gateway .
Best regards
Akram
12-23-2020 11:50 AM
Hi ,
what does make you think that the call from the DN 999 would use GW2?
Because the second BRI use line : 0537635777.
I have question , can i use two lines BRI , each one in their gateway .
ISR1 with BRI1 (0537635766)
ISR2 with BRI2 (0537635777)
The two ISR are added on RG on top down . After associated it on RL.
For example ip phone 555 outgoing call by BRI1.
And ip phone 999 outgoing call by BRI2.
Is that possible in this scenario ?
Best regards
12-23-2020 12:57 PM
Just “Because the second BRI use line : 0537635777” it doesn’t by magic use that for egress calls when you call from the DN (999) that belongs to this BRI. You have to create the needed configuration for this in CUCM.
12-23-2020 12:24 PM
Thank you for your reply.
Is that possible to make a outgoing call by BRI2 on gateway 2 . With gateway grrouped on RL top down . Or when the gateway 1 not function in that way i can use BR2 on gateway 2 ?
Best regards
12-23-2020 12:42 PM - edited 12-24-2020 12:30 AM
What you ask is absolutely possible. I previously described the configuration you need and what you have is not it. You have to create configuration in CUCM to send calls out the appropriate BRI circuit based on the DN that makes the call. Create something like this.
There are other options for how achieve this, but this would be the way to use the most up to date style of configuration. For additional details on how this works have a look at this post, https://www.uccollabing.com/configuring-standard-local-route-group-cucm/
12-24-2020 02:31 AM
I updated my reply from yesterday with more detailed information on what you’d need. Please have a look at it.
12-24-2020 10:04 AM
Thank you for your rich informations and your help.
12-23-2020 08:17 PM
Did you tried this on gateway 1 ?
12-24-2020 10:01 AM
Hi yes i tried it .
12-25-2020 08:25 AM
Whats the update after trying the configuration.
12-25-2020 03:59 AM
Calling 999 number from debug Snip'
//197/8034971B1B00/CCAPI/ccIFCallSetupRequestPrivate:
Interface=0x7F81BED0D5A8, Interface Type=6, Destination=, Mode=0x0,
Call Params(Calling Number=999,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
Called Number=0638884592(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=5, Call Count On=FALSE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
Dec 23 11:29:26.230: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
12-25-2020 04:44 AM - edited 12-25-2020 05:25 AM
If you look in more detail in the debug you’ll see that the calling number is translated in the GW.
Before translation
Dec 23 11:29:26.227: //-1/8034971B1B00/CCAPI/cc_api_display_ie_subfields:
cc_api_call_setup_ind_common:
cisco-username=
----- ccCallInfo IE subfields -----
cisco-ani=999
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=1
dest=0638884592
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFFFFFFFFFF
cisco-rdn=
cisco-rdntype=-1
cisco-rdnplan=-1
cisco-rdnpi=-1
cisco-rdnsi=-1
cisco-redirectreason=-1 fwd_final_type =0
final_redirectNumber =
hunt_group_timeout =0
After translation
Dec 23 11:29:26.234: //197/8034971B1B00/CCAPI/ccCallSetupRequest:
Calling Number=0537635777(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
Redirect Number=, Display Info=
Account Number=, Final Destination Flag=TRUE,
Guid=8034971B-3831-9148-1B00-6C010AD41606, Outgoing Dial-peer=6
Dec 23 11:29:26.234: //197/8034971B1B00/CCAPI/cc_api_display_ie_subfields:
ccCallSetupRequest:
cisco-username=
cisco-ani=0537635777
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=1
dest=0638884592
cisco-desttype=0
cisco-destplan=0
cisco-rdn=
cisco-rdntype=-1
cisco-rdnplan=-1
cisco-rdnpi=-1
cisco-rdnsi=-1
As I wrote before, if it’s still not what is presented as the calling number on the receiving end the calling number is changed by the telco. You’d have to discuss this with them to find out if they have the option to let the calling number pass untouched. If not you'd have to do good with that you can get the correct calling number if the call egress out via the circuit where the phone number resides.
12-25-2020 04:02 AM
IS there is any translation route configured in the CUCM or Application rule configured in the CUCM
12-25-2020 04:45 AM
Neither of these would be of any good here.
