Translation Pattern in CUBE 2921 series
mohammad saeed
Level 5
Level 5
Hi guys,
I m fresh in VoIP and I found one CUBE connect with SIP and CUCM with this destination pattern:
dial-peer voice 9 voip
description **Outgoing Call to STC SIP Trunk**
destination-pattern 01[123456789].......
rtp payload-type comfort-noise 13
session protocol sipv2
session target ipv4:10.200.7.157
session transport udp
voice-class sip dtmf-relay force rtp-nte
dtmf-relay rtp-nte digit-drop
codec g711alaw
no vad
My question is 01[123456789]..... "I didn't find explanation for that way without comma or hyphen! what is it mean those number together [123456789] is it the same if i use it with commas [1,2,3,4,5,6,7,8,9]??
Thanks for all
Mohammad Saeed
devils_advocate
Level 7
Level 7
As far as I know it means the same as 1 through 9 so the following three mean the same thing:
[1-9]
[123456789]
[1,2,3,4,5,6,7,8,9]
FYI, this is a destination pattern as opposed to a translation pattern.
You are not translating anything, you are matching based on the Called Number.
8 Replies 8
Chris Deren
Yes, they are the same, but proper syntax is to use commas between them, though it works either way. You can also summarize it as [1-9].
devils_advocate
Level 7
Level 7
[1-9]
[123456789]
[1,2,3,4,5,6,7,8,9]
devils_advocate,
Comma should be used, see:
http://www.cisco.com/c/en/us/td/docs/ios/12_2/voice/configuration/guide/fvvfax_c/vvfpeers.html
Indicates a range of digits. A consecutive range is indicated with a hyphen (-); for example, [5-7]. A nonconsecutive range is indicated with a comma (,); for example, [5,8]. Hyphens and commas can be used in combination; for example, [5-7,9].
Note Only single-digit ranges are supported. For example, [98-102] is invalid.
My bad.
I edited my post straight after, I was thinking translation pattern initially.
So if I didn't use commas that means is wrong destination pattern?
It still works, though the proper syntax is to use commas, many folks miss that because it works both ways :-)
Good, but why choose [123456789] instead of [1-9] what is the benefit of that?
No benefit, you would want to change it to [1-9].
