Highlighted
Beginner
Translation pattern in CUCM doesn't work as I want??
Earlier I could call from translation pattern with mask in configured Translation Pattern. Now I cann't . Is it some bug??
CSS, Partitions and Translation pattern configured right
8 REPLIES 8
Highlighted
Beginner
Re: Translation pattern in CUCM doesn't work as I want??
When I call #933555555 I want to go out to PSTN with number 782090
but I go out with line external mask number
Highlighted
Please, use dialed number analyser tool and post the output?
Highlighted
Beginner
Results Summary
Calling Party Information
Calling Party = 782099 <--RIGHT NUMBER
Partition =
Device CSS =
Line CSS = Kiev_Employers_CSS
AAR Group Name =
AAR CSS =
Dialed Digits = #933782200
Match Result = RouteThisPattern
Matched Pattern Information
Pattern = [27]XXXXX
Partition = Lt_City_PT
Time Schedule =
Called Party Number = 782200
Time Zone = Greenwich Standard Time
End Device = Lt_RL
Call Classification = OnNet
InterDigit Timeout = NO
Device Override = Disabled
Outside Dial Tone = NO
Call Flow
TranslationPattern :Pattern= #933.!
Positional Match List = 782200
Calling Party Number = 782099
PreTransform Calling Party Number = 1129
PreTransform Called Party Number = #933782200
Calling Party Transformations
External Phone Number Mask = NO
Calling Party Mask = 78209X
Prefix =
CallingLineId Presentation = Default
CallingName Presentation = Default
ConnectedParty Transformations
ConnectedLineId Presentation = Default
ConnectedName Presentation = Default
Called Party Transformations
Called Party Mask =
Discard Digits Instruction = PreDot
Prefix =
Called Number = 782200
Route Pattern :Pattern= [27]XXXXX
DialPlan =
Route Filter
Filter Name =
Filter Clause =
Require Forced Authorization Code = No
Authorization Level = 0
Require Client Matter Code = No
PreTransform Calling Party Number = 782099
PreTransform Called Party Number = 782200
External Phone Number Mask = YES
Prefix =
Called Party Mask =
Discard Digits Instruction = None
Prefix =
Route List :Route List Name= Lt_RL
RouteGroup :RouteGroup Name= Lt_RG
External Phone Number Mask = Default
Prefix =
Called Party Mask =
Discard Digits Instructions =
Prefix =
Device :Type= MGCPE1PRIPort
End Device Name = S0/SU0/DS1-0@C3825.cisco.net
PortNumber = 0
Device Status = Registered
AAR Group Name =
AAR Calling Search Space =
AAR Prefix Digits =
Calling Party Selection =
CallingLinePresentation =
ConnectedLinePresentation =
Number Of Strip Digits =
CallerID DN =
Alternate Matches
Note: Information Not Available
Highlighted
Beginner
debug isdn q931
Jan 19 13:28:29.136: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8 callref = 0x00A0
Sending Complete
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA9839E
Exclusive, Channel 30
Calling Party Number i = 0x0081, '5930029' <-- NO NEEDED NUMBER
Plan:Unknown, Type:Unknown
Called Party Number i = 0x80, '780002'
Jan 19 13:28:29.152: ISDN Se0/0/0:15 Q931: RX <- CALL_PROC pd = 8 callref = 0x80A0
Jan 19 13:28:29.300: ISDN Se0/0/0:15 Q931: RX <- ALERTING pd = 8 callref = 0x80A0
Jan 19 13:28:30.044: ISDN Se0/0/0:15 Q931: RX <- CONNECT pd = 8 callref = 0x809F
Channel ID i = 0xA9839F
Exclusive, Channel 31
Date/Time i = 0x0901130F1C00
Highlighted
Hall of Fame Cisco Employee
in the past when i've seen this the issue wasn't even CCM, it was the GW.
the only way to confirm this is getting a CUCM detailed trace, looking at the call info line for the call and reviewing the setup message sent by CUCM, if all the info matches but still the GW sends something else the options are try a no mgcp/mgcp and/or reload the GW
java
if this helps, please rate
java
Highlighted
Beginner
I was very confused when saw that this solution doesn't work.
It worked with CCM 4.3 - but after upgrade I only now checked that I have some problems.
I have done no mgcp / mgcp ofcourse, but it was helped.
Let's try to to upgrade CUCM..
Highlighted
Enthusiast
Have you tried restarting CCM service?
Txs
Pedro
Beginner
Not yet..I think this could help me
