Translation pattern outside dialtone
Yuriy Ivkin
Beginner
Beginner
Greetings!
I tried to configure translation pattern, which translate 4 digit number into 10 digit national format. I expected that call made through this TP will be routed farther, but instead i heard outside dialtone (checkbox was unchecked). Could anyone explain, why that happened ? Thanks in advance for your answers.
What do you mean by "TP will be routed farther" Did you check "urgent priority" (it is be checked by default), if you are hearing outside dial tone that means you are running into overlap patterns..There is a pattern macthed that is similar to the TP. Use route plan report to see which similar pattern matches and uncheck outdise dial tone on it
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
I mean call with translated called number will be routed further (Next loop of match with dialplan).
Yes, it was checked on TP.
No, there isn't. I cheked that. Could be problem, that translated called number matched to route pattern which looks like this: 011.!. But there is another one, which looks like this: 011.!#. And because of that i got outside dialtone ?
Jaime Valencia
Hall of Fame Cisco Employee Hall of Fame Cisco Employee
Use DNA to find out exactly what you're matching in your dial plan.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Greetings!
The problem definitely not in overlap patterns. If i create route pattern with the same DN and call, i get right on it.
That's solve problem, but i want to understand, why solution with TP don't work.
Recognize Your Peers
