Translation Pattern Wild Card
Shri2
Beginner
Beginner
Hello Team,
I am trying to create a single TP which should match E164 and non-E164 number, but i am unable to do.
\+.! --> This TP is to match a E164 number.
!     --> This TP is to match any number ( but not E164 number )
I am not able to combine both in 1 TP.
Is there a way to create 1 TP which can match both number format ?
Jaime Valencia
No, that should not be possible, simply create the two patterns for your scenario.
java
if this helps, please rate
Thank you!!
Eric Ingram
Enthusiast
Enthusiast
You need to create 2 patterns.
Thank you for the response!!
