Translation Pattern Wild Card
Shri2
Hello Team,
I am trying to create a single TP which should match E164 and non-E164 number, but i am unable to do.
\+.! --> This TP is to match a E164 number.
!     --> This TP is to match any number ( but not E164 number )
I am not able to combine both in 1 TP.
Is there a way to create 1 TP which can match both number format ?
Jaime Valencia
No, that should not be possible, simply create the two patterns for your scenario.
java
if this helps, please rate
Thank you!!
Eric Ingram
Level 4
Level 4
You need to create 2 patterns.
Thank you for the response!!
