05-20-2022 08:23 AM
Hi All,
I have an issue with international calls , where the phone is sending call as +91XXX but I want send it as 0091.
Can any one suggest the translation Rule for it and do i need to apply it on incoming Dial-peer or outgoing dial peer.
Solved! Go to Solution.
05-20-2022 11:34 AM
This should do what you ask for.
voice translation-rule 10
rule 1 /^\+\(91.*\)/ /00\1/
voice translation-profile PSTN-OUT
translate calling 10
Apply this to your outbound dial peer in the outbound direction.
For additional information on voice translations have a look at this document.
05-20-2022 09:54 AM
There's a lot of existing documentation around translation rules, which has plenty of examples for various scenarios, have you reviewed it?
I'd also suggest you review the existing documentation around how dial peers work if you're not clear on which dial peers to apply it for your scenario.
05-20-2022 11:34 AM
06-02-2022 07:53 AM
It is working, Thank you
