02-21-2015 06:26 AM - edited 03-17-2019 02:04 AM
Hi Guys, i really need a help with the isdn incoming calls that are not working.
Translation rule not working, whats wrong?
Here are the configurations and the debug q931 outputs :
card type e1 0 0
voice-card 0
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol pass-through g711ulaw
h323
sip
bind control source-interface GigabitEthernet0/0
bind media source-interface GigabitEthernet0/0
min-se 1200 session-expires 1200
registrar server expires max 1200 min 300
voice class codec 1
codec preference 1 g711alaw
codec preference 2 g711ulaw
codec preference 3 g729r8
voice class codec 2
codec preference 1 g729r8
voice register global
mode cme
source-address 10.x.x.x port 5060
max-dn 44
max-pool 44
load 8961 sip8961.9-4-2SR1-2.loads
load 7821 sip78xx.10-2-1-12.loads
authenticate register
timezone 25
time-format 24
date-format D/M/Y
tftp-path flash:
create profile sync 0016088381731508
voice register dn 1
translation-profile incoming DID
number 5100
pickup-group 1
name Test
label Test
mwi
voice register dn 2
number 5101
pickup-group 1
name Test
label Test
mwi
voice register dn 3
number 5102
pickup-group 1
name Test3
label Test3
mwi
voice register dn 4
number 5103
name CIPC
label CIPC
mwi
voice register pool 1
busy-trigger-per-button 2
id mac 8480.2DD5.A1A2
feature-button 2 PickUp
type 7821
number 1 dn 1
presence call-list
dtmf-relay rtp-nte
username 5100 password 5100
codec g711ulaw
voice register pool 2
id mac 8480.2DD5.A22D
type 7821
number 1 dn 2
presence call-list
dtmf-relay rtp-nte
username 5101 password 5101
codec g711ulaw
voice register pool 3
id mac 8480.2DD5.A12D
type 7821
number 1 dn 3
presence call-list
dtmf-relay rtp-nte
username 5103 password 5103
codec g711ulaw
voice register pool 4
id mac 8480.2D76.9E22
type 8961
number 1 dn 4
presence call-list
dtmf-relay rtp-nte
username 5104 password 5104
codec g711ulaw
voice register pool 5
voice translation-rule 1
rule 1 /56065\(..\)/ /51\1/
voice translation-profile DID
translate called 1
controller E1 0/0/0
framing NO-CRC4
pri-group timeslots 1-31
description from PSTN
interface Embedded-Service-Engine0/0
no ip address
description ===Main_SW===
ip address 10.x.x.x 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0:15
no ip address
encapsulation hdlc
isdn switch-type primary-net5
isdn overlap-receiving T302 4000
isdn incoming-voice voice
isdn bchan-number-order ascending
isdn sending-complete
no cdp enable
ip default-gateway 10.x.x.x
ip forward-protocol nd
no ip http server
ip http access-class 23
ip http authentication aaa
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip route 0.0.0.0 0.0.0.0 10.x.x.X
voice-port 0/0/0:15
local-alerting
no mgcp package-capability res-package
no mgcp package-capability fxr-package
no mgcp timer receive-rtcp
no mgcp explicit hookstate
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
no ccm-manager fax protocol cisco
dial-peer voice 1 voip
description ***To_CUCM1***
destination-pattern [1-4]...
session protocol sipv2
session target ipv4:10.x.x.x
voice-class codec 1
dtmf-relay h245-alphanumeric
no vad
dial-peer voice 2 voip
description ***To_CUCM2***
destination-pattern 50..
session target ipv4:192.x.x.x
voice-class codec 1
no vad
dial-peer voice 1000 pots
description International
destination-pattern 900.T
port 0/0/0:15
forward-digits 14
dial-peer voice 1001 pots
description Mobile
preference 1
destination-pattern 905[0345]........
port 0/0/0:15
forward-digits 11
dial-peer voice 1002 pots
description PSTN
preference 2
destination-pattern 90[234678].........
port 0/0/0:15
forward-digits 11
dial-peer voice 1003 pots
description Shirt No
preference 3
destination-pattern 91..
port 0/0/0:15
forward-digits 3
dial-peer voice 10000 pots
incoming called-number .T
direct-inward-dial
port 0/0/0:15
telephony-service
max-conferences 8 gain -6
call-park system application
transfer-system full-consult
VGW#test voice translation-rule 1 5606500
Matched with rule 1
Original number: 5606500 Translated number: 5100
Original number type: none Translated number type: none
Original number plan: none Translated number plan: none
VGW#debug isdn q931
debug isdn q931 is ON.
Etsun_Tuzla_VGW#
Feb 21 16:24:26: ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8 callref = 0x014D
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98381
Exclusive, Channel 1
Calling Party Number i = 0x2183, '0994503461819'
Plan:ISDN, Type:National
Called Party Number i = 0xC1, '5606500'
Plan:ISDN, Type:Subscriber(local)
Sending Complete
Feb 21 16:24:26: ISDN Se0/0/0:15 Q931: Received SETUP callref = 0x814D callID = 0x0006 switch = primary-net5 interface = User
Etsun_Tuzla_VGW#
Feb 21 16:24:26: ISDN Se0/0/0:15 Q931: TX -> CALL_PROC pd = 8 callref = 0x814D
Feb 21 16:24:26: ISDN Se0/0/0:15 Q931: TX -> DISCONNECT pd = 8 callref = 0x814D
Cause i = 0x8081 - Unallocated/unassigned number
Feb 21 16:24:26: ISDN Se0/0/0:15 Q931: RX <- RELEASE pd = 8 callref = 0x014D
Feb 21 16:24:26: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x814D
VGW#
Solved! Go to Solution.
02-21-2015 06:47 AM
Hi Murat,
I see that you have applied the translation on the voice register dn:
voice register dn 1
If the call flow is as given below, then the translation profile needs to applied on the PSTN dial-peer in order for this to work.
PSTN --> PRI --> CME --> voice register dn in CME
Please try applying "translation-profile incoming DID" on the PSTN dial-peers pointing to the PRI and if the issue persists, please also provide "debug voip ccapi inout" to check further.
HTH,
Shenbagarajan
02-21-2015 06:47 AM
Hi Murat,
voice register dn 1
HTH,
Shenbagarajan
02-21-2015 08:13 AM
Hi Shenbagarajan,
Thank you for your quick response.
I added new incoming dial-dialpeer and everything works.
Thank you very much.
description Incoming
no digit-strip
direct-inward-dial
port 0/0/0:15
02-21-2015 10:32 AM
Glad it worked.
