translator x for cuc?
balitewiczp
Level 2
Level 2
Is there a tool like translator x that would allow me to look at trace files from unity connection?
Wilson Samuel
Level 7
Level 7
If there is any tool, it should appear on the http://www.ciscounitytools.com/
However just wondering what are you trying to troubleshoot?
I have both sccp and sip phones where the Idivert key does not work.  Basically doesnt do anything.   only 1 active call, and with more than 1 active calls.   Tried various flavors of 9.3.1Sr1 and Sr4 sccp and sip loads.
Was just looking for traces so i could see if its hitting vm server.
Jaime Valencia
No
java
if this helps, please rate
