TrnsfVM to external CUE with VPIM
daryls
Frequent Visitor
Frequent Visitor
Scenario is this
SiteA
SiteB
External/Internal call into SiteA to general number. User needs to transfer call to SiteB users Voicemail using the TrsnfVM softkey in CME.
VPIM networking is configured between SiteA and SiteB
users are configured as remote users. Callers receive their is no mailbox for that extension on this system.
Regular voicemail functions work fine.
Config below
network location id 111
email domain 10.1.1.253
name SiteA
voicemail phone-prefix 1
voicemail extension-length 4
voicemail vpim-encoding G711ulaw
voicemail spoken-name
end location
remote username wwww location 222 create
remote username wwww phonenumber "2113"
network location id 222
email domain 10.1.2.253
name SiteB
voicemail phone-prefix 2
end location
remote username vvvvvv location 111 create
remote username vvvvvv phonenumber "1128"
I see you are missing these:
ip domain-name
ip name-server
you must have dns for VPIM to work
Haitham
ip domain-name
ip name-server
Haitham
daryls
Frequent Visitor
Frequent Visitor
name-server is configured. For the email domain, using the IP address.
The issue is the call comes into cue from the traces as the extension of the remote users and CUE doesn't know to route it to the remote mailbox using the "TrnsfVM" softkey
Try to test it using FAC and check your traces
If not work, Then think for some limitation at this point
Haitham
