07-22-2015 03:40 PM - edited 03-17-2019 03:44 AM
Hola mi duda es si tengo un BE6K y quiero integrarlo a un CUCM quien dara servicios de telefonia a varias oficinas remotas, la integracion seria atraves de una troncal SIP entre ambos equipos, los cuales llegaran conectarse atraves de una red WAN MPLS, estos equipos no estaran en cluster cada uno contara con sus extensiones y su propio dominio, mi pregunta si es necesario algun licenciamiento para las troncales SIP o un gateway con licenciamiento CUBE, o simplemente se realiza la confirguracion de la troncal sip entre los dos equipos?
07-22-2015 04:27 PM
Could you please post a translated version of this in English please
07-22-2015 04:48 PM
Sí deseas postear en español, por favor hazlo en la comunidad de dicho idioma, esta comunidad es dedicada al ingles. Usa el drop-down de Language al lado de Contact Us en la parte superior para ello.
En cuanto a tu pregunta, sí, el 6K tiene los mismos features que cualquier otro CUCM.
07-22-2015 04:51 PM
sure, i have a be6k equipment and I wanto to connect at CUCM( it connects at endpoints in many remote office through MPLS wan link), so I want to connect both (be6k and CUCM) with a SIP Trunk through MPLS WAN, my question is: is it possible withouth adding licensing to create trunk sip on both equipments? or i have to add a gateway with CUBE licensing? Also both equipments have different endpoint registers, I mean they are not be cluster.
I apologize for my grammar :) or traslation
07-22-2015 05:19 PM
Yes, you could directly terminate SIP Trunks from the PSTN to call managers. However doing that is potentially exposing your IP Addressing as well as Callmanager to outside world
it is doable and i have had few of my customers do just that.
however if you have any C2900 router with Voice Bundle Cisco gives out 5 CUBE lic (I think) for free (it is part of the bundle) , so that means if you have 2 C2900 then you can essentially have 10 lines for not additional cost
07-22-2015 11:17 PM
His question is way simpler than that, he's just asking if he can create a SIP trunk from cluster A to cluster B over MPLS, to which the answer is, yes.
