02-06-2020 09:26 PM
I'm trying to get a 8821 registered on a 2901 using Fast Track. I cannot seem to get the phone registered. Any help would be appreciated.
2801 running Version 15.4(3)M3.
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
redirect ip2ip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback pass-through g711ulaw
h323
call start slow
sip
bind control source-interface GigabitEthernet0/0.100
bind media source-interface GigabitEthernet0/0.100
registrar server
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g722-64
codec preference 3 ilbc
codec preference 4 g729r8
codec preference 5 g723r63
codec preference 6 g723r53
voice class h323 1
h225 timeout tcp establish 3
voice class sip-profiles 1
voice register pool-type 8821
xml-config maxNumCalls 4
xml-config busyTrigger 2
phoneload-support
transport tcp
num-lines 2
description Cisco IP Phone 8821
reference-pooltype 9971
voice register global
mode cme
source-address 192.168.100.254 port 5060
max-dn 100
max-pool 20
load 8821 sip8821.11-0-5SR1-4.loads
authenticate register
tftp-path flash:
create profile sync 2280551830134653
voice register dn 1
number 1152
name Production Room
label 1152-Production
voice register dn 2
number 2152
name Intercom Production Room
label Intercom - Production Room
voice register pool 1
id mac ACF5.367B.9D36
session-transport tcp
type 8821
number 1 dn 1
number 6 dn 2
dtmf-relay rtp-nte
codec g711ulaw
paging-dn 39
******#sh voice register tftp-bind
tftp-server url flash:/its/syncinfo.xml alias syncinfo.xml
tftp-server url flash:/its/SIPDefault.cnf alias SIPDefault.cnf
tftp-server url flash:/its/softkeyDefault_kpml.xml alias softkeyDefault_kpml.xml
tftp-server url flash:/its/softkeyDefault.xml alias softkeyDefault.xml
tftp-server url flash:/its/featurePolicyDefault.xml alias featurePolicyDefault.xml
tftp-server url flash:/its/SEPACF5367B9D36.cnf.xml alias SEPACF5367B9D36.cnf.xml
#debug ccsip message
Feb 6 23:17:08.987 CST: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
REFER sip:192.168.100.254 SIP/2.0
Via: SIP/2.0/UDP 192.168.100.124:5060;branch=z9hG4bK510468cf
From: "" <sip:@192.168.100.124>;tag=acf5e67b9d3604846bb9e86f-0a325a9d
To: <sip:192.168.100.254>
Call-ID: acf5e67b-9d360484-3aea8ec6-616e72a1@192.168.100.124
Session-ID: 0b17ff4600105000a000acf5e67b9d36;remote=00000000000000000000000000000000
Date: Fri, 07 Feb 2020 05:17:09 GMT
CSeq: 1000 REFER
User-Agent: Cisco-CP8821/11.0.5
Expires: 10
Max-Forwards: 70
Contact: <sip:@192.168.100.124:5060;transport=udp>;+u.sip!devicename.ccm.cisco.com="SEPACF5E67B9D36"
Require: norefersub
Referred-By: "" <sip:@192.168.100.124>
Refer-To: cid:6051a56f@192.168.100.124
Content-Id: <6051a56f@192.168.100.124>
Allow: ACK,BYE,CANCEL,INVITE,NOTIFY,OPTIONS,REFER,REGISTER,UPDATE,SUBSCRIBE
Content-Length: 1366
Content-Type: application/x-cisco-alarm+xml
Content-Disposition: session;handling=required
<?xml version="1.0" encoding="UTF-8"?>
<x-cisco-alarm>
<Alarm Name="LastOutOfServiceInformation">
<ParameterList>
<String name="DeviceName">SEPACF5E67B9D36</String>
<String name="DeviceIPv4Address">192.168.100.124/24</String>
<String name="IPv4DefaultGateway">192.168.100.254</String>
<String name="DeviceIPv6Address"></String>
<String name="IPv6DefaultGateway"></String>
<String name="ModelNumber">CP-8821</String>
<String name="NeighborIPv4Address"></String>
<String name="NeighborIPv6Address"></String>
<String name="NeighborDeviceID"></String>
<String name="NeighborPortID"></String>
<Enum name="DHCPv4Status">1</Enum>
<Enum name="DHCPv6Status">3</Enum>
<Enum name="TFTPCfgStatus">1</Enum>
<Enum name="DNSStatusUnifiedCM1">4</Enum>
<Enum name="DNSStatusUnifiedCM2">0</Enum>
<Enum name="DNSStatusUnifiedCM3">0</Enum>
<Enum name="DNSv6StatusUnifiedCM1">0</Enum>
<Enum name="DNSv6StatusUnifiedCM2">0</Enum>
<Enum name="DNSv6StatusUnifiedCM3">0</Enum>
<String name="VoiceVLAN"></String>
<String name="UnifiedCMIPAddress"></String>
<String name="LocalPort"></String>
<String name="TimeStamp">1579286362969</String>
<Enum name="ReasonForOutOfService">107</Enum>
<String name="LastProtocolEventSent"></String>
<String name="LastProtocolEventReceived"></String>
<String name="ReasonForOutOfServiceText">LastTimeUpgrade</String>
</ParameterList>
</Alarm>
</x-cisco-alarm>
Feb 6 23:17:08.991 CST: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
******#SIP/2.0 400 Bad Request
To: <sip:192.168.100.254>;tag=BE27EB00-23E2
Date: Fri, 07 Feb 2020 05:17:08 GMT
Server: Cisco-SIPGateway/IOS-15.4.3.M3
CSeq: 1000 REFER
Content-Length: 0
Contact: <sip:192.168.100.254:5060>
02-07-2020 08:19 PM
02-07-2020 10:19 PM
02-12-2020 11:32 AM
Any other suggestions? I'm at a loss.
