Sergio Arroyo
Beginner
Trouble saving changes in CUCM 8.5
Dear
The problem is as follows:
When I try to save changes to settings for the Cisco 6961 and 3905 model in CUCM 8.5, this does not save.
I have other models of phones configured in CUCM and I have no problems to save the changes, only happens with the two models mentioned.
For the 6961 model upgrade to the latest version available on the website of cisco, but the problem persists.
Please help with this issue.
thanks
regards
4 REPLIES 4
Chris Deren
Hall of Fame Master
How do you figure the changes are not saved?  Are they not showing in the GUI configuration? Or the configuration does not seem to work? What changes are you making?
Chris
Chris
first of all, thank you very much for the help
I'll explain:
When I save a change to the Phone Setup screen, whatever, the changes are not saved. However, when I make changes in the display line configuration, the same phone, I have no problems.
At one point seemed to be a problem of the browser you were using (Internet Explorer), but I tried it with Mozilla and the problem has persisted
I hope I have explained the problem and can help me.
thank you very much
Watch for your feedback.
Hi Sergio
I think you maybe hitting this Defect:   CSCtf70210
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCtf70210
As a work-around can you please run the following command on the cucm publisher CLI :
run loadxml
Then check if this fixes your issue.
The bug was first discover in cucm version 7 , but cucm 8.x was also affected by this.
Aditya Gupta
Dear Aditya
perform the configuration I indicated in the publisher, but the problem persists.
Do you have any other ideas on this issue?
Attentive to your comments
Sergio
Content for Community-Ad
Spotlight Awards 2021
