I have a few users that are part of the main number hunt group. Recently they have had random issues with calls dropping during a transfer. I have times and incoming caller ID's. How can I go about tracking down why caused the call to drop and how to implement a resolution.
Cisco Unified CM Administration
System version: 10.5.2.12901-1
Cisco Unified Intelligence Center
Version:10.6(1) build 1 (10_6_1_11003_29)
Cisco Unified Attendant Console
Administration Version: 10.5.2.690
Hi folllysurfer,
Also if you can post the CUCM SDL logs for the same call, we can explain the logs, get you the disconnect cause code and resolution.
Thanks.
Based on this article, trace is not setup for the system. I have enabled it however will this help with reports from last week? Is there another place I can retrieve the information in lieu of tracing not being enabled?
I don't think so, if the required check boxes were not enabled, the system would not have generated the logs. You have to collect the logs hereafter.
