Troubleshooting cause code 47
yvonneobiero
at the moment the gateway has not yet been deployed and is not in active use. sh call history voice brief output on gateway is shown below
Telephony call-legs: 0
SIP call-legs: 0
H323 call-legs: 10
Call agent controlled call-legs: 0
Media call-legs: 0
Total call-legs: 10
1DB6 : 409 433052630ms.409 +-1 +11810 pid:20 Answer 235
dur 00:00:00 tx:0/0 rx:0/0 2F  (no resource (47))
IP 0.0.0.0:0 SRTP: off rtt:0ms pl:0/0ms lost:0/0/0 delay:0/0/0ms g729r8 pre-iet
f TextRelay: off
media inactive detected:n media contrl rcvd:n/a timestamp:n/a
long duration call detected:n long dur callduration :n/a timestamp:n/a
Any solution on how to resolve this issue, will be most welcome.
paolo bevilacqua
You call an 8 digits number, but have configured 3 in the DP.
There are a couple of dial-peers being used apart from that one.. so after putting in voice service voip commands on gateway, the new error that i get is Cause code 47 is No Resources Available.....and the dial peer does get matched
Jan 30 08:55:32.910: //426/80ED719CE300/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x4777AD20, Interface Type=1, Destination=, Mode=0x0,
   Call Params(Calling Number=235,(Calling Name=)(TON=Unknown, NPI=Unknown, Scre
ening=User, Passed, Presentation=Allowed),
   Called Number=118118883237117(TON=Unknown, NPI=Unknown), Calling Translated=F
ALSE,
   Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=21
, Call Count On=FALSE,
You can then enable debug cch323 to troubleshoot further.
Hi Bevilacqua,
will do that on monday and post the output.
have a gud weekend
