6648
sip.support
Beginner
Trunk E1 Router c2811 to Panasonic TDA600 PBX
Hi, i'm ryan. i wanna ask about my problem here.
There is a topology like this:
Phone_A (extension: 3304) - PBX - Router - Phone_B (FXS - extension 8989).
To connect Router to PBX using E1.
the PBX is a Panasonic TDA600 and connection to the router using PRI Module 30ch,
the Router is C2811 Router include VWIC2-2MFT-T1/E1 for connection to the PBX.
Router and PBX located in one building.
I have configure the router (capture attached). And was able to make calls from Phone_A to Phone_B (direct extension).
the PBX also have been configured, for a number that begins with 89 will be passed to the trunk-group PRI30ch
. From PBX to test the connection to the router, it is checked by calling* 851 from Phone_A, if the connection is correct, then Phone_A will receive a long tone,and now it was successful & no problem.
Now the problem is, Phone_A can not directly dial the extension of Phone_B (appears busy tone). but Phone_A can call Phone_B by call * 851 first, if it receive long tone, and we press extension 8989 so the calls can be really successfully.
I need solution? how to Phone_A can directly call Phone_B, direct call the extention i mean,not using the * 851 first.
Hopefully anyone can help me.
Thank's before for the help.
Ryan
19 REPLIES 19
acampbell
Advocate
Ryan,
Can you clear up your design before I can help you.
I think your system is like this from the config you have shown.
3304 - PAN/PBX --- E1/QSIG ---- ROUTER -----FX? --- 8080
You are mentioning 8989 I dont see any peer for this.
There are a few other items missing from the config
Can you please verify the design and explain what number ranges are in each side of the network.
Alex.
Regards, Alex. Please rate useful posts.
Alex,
oh, i'm sorry, i forget to change, the ekstension is 8080, thanks for the correction.
for the design is like this :
3304 - PAN/PBX ---- E1/QSIG ---- ROUTER ----- FXS --- 8080
thanks for the help before.
Ryan
Ryan,
Can you try adding the following line to your config
network-clock-select 1 E1 0/0/0
! THIS FIXES THE ISDN LINE CLOCKING TO COME FROM THE TRAD PBX
interface Serial0/0/0:15
isdn overlap-receiving T302 2000
dial-peer voice 1 pots
description *** FOR INCOMING CALL MATCHING ***
! Match Incoming PSTN calls to this peer !
incoming called-number .
! THIS NEEDS THE FULLSTOP
direct-inward-dial
port 0/0:15
dial-peer voice 3304 pots
direct-inward-dial
Then try retesting
Let us know how it goes
Alex
Alex,
oke, i will try it. and publish the result here.
but, i have a question. is it posible that the problem is not the router but the panasonic tda 600 pbx??
cause call from router to pbx is working fine, and call from pbx to router that not working fine.
thanks before for the advise .
Best Regards,
Ryan
Ryan,
Your existing config does not allow direct dialling in to the router from the PBX.
The issue you may need to look at on the PBX is how to access the QSIG trunk from that side.
Your notes above state you needed to dial *851 first.
I am not sure if this is a MUST or does the routing table in the PBX point calls to 8080 down the
QSIG trunk.
Make the changes I sent then retest.
Let us know the results.
Alex
Dear Alex,
thanks before, the problem is solve now, the problem occur because the pabx, when i add the ip of router to the pabx, all is working fine. thank you very much for the answer.
and the *851 is a feature of panasonic pbx to test the link from pbx to router. in the past, i install a new pri card in pbx, and allocate that card to trunk group 51, so the explanation of *851 is *8 is the feature of pbx, and the 51 is the trunk group.and we also make a leading number 89 to the trunk group 51. so if there is a call begin with 89, the pbx will route that call through trunk-group 51.
but another problem is occur the router now just receive 2 last digit, example when i call 8987, the router just receive 2 last digit -> 87, so from that, i make dial-peer voice 87 pots, and the port is to pots through fxs port. (the config and capture of debug isdn q931 and debug voice translation is attached).
my question is, how to make the router can receive all 4 digits from pbx?? because i need to receive all the 4 digit.
* i make a change, the pots which connected to router is changed to 8987.
thank you very much for the help.
Best regards,
Ryan
Ryan
Make sure that the PBX is sending all 4 digits
You may be using overlap signalling on the PBX side
Try adding this peice of config.
Let us know how you get on
Alex
Dear Alex,
i have add this config :
but nothing change, and after i add that config, i can't call from phone that connected to pabx to phone that connected to router.
i wanna ask, how to make sure that the PBX is sending all 4 digits??
Thank you very much before.
Best regards,
Ryan
Ryan,
I dont know how to help you with the PBX
Looking at the Q931 trace
Called Party Number i = 0x89, '89'
It looks like you are only getting "89" from the PBX.
Other than putting some Q931/QSIG analyser in series in the trunk you need help from panasonic support.
Alex
hi acampbell
i dont know what do i do for this
please help me
Current configuration : 2787 bytes
version 12.4
hostname R1
boot-start-marker
boot-end-marker
card type e1 0 3
logging message-counter syslog
enable secret 5 $1$l4aA$qLLYjc/eUTeVm8ArOA3gh.
no aaa new-model
network-clock-participate wic 3
dot11 syslog
ip source-route
ip cef
ip domain name alish
no ipv6 cef
isdn switch-type primary-qsig
voice call send-alert
voice rtp send-recv
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol cisco
voice class codec 1
codec preference 1 g711alaw
codec preference 2 g711ulaw
voice-card 0
! Warning! DSPs 5,6,7,8 in slot 0 are using non-default firmware from device flash:
! This is not recommended, the IOS default version is 24.3.4
username alish privilege 15 secret 5 $1$Wi7e$KuYtp3rQLvBzajnOTEndK.
archive
log config
hidekeys
controller E1 0/3/0
framing NO-CRC4
pri-group timeslots 1-31
controller E1 0/3/1
framing NO-CRC4
clock source internal
ip ssh version 2
interface FastEthernet0/0
ip address 192.168.20.6 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/3/0:15
no ip address
encapsulation hdlc
isdn timer T310 120000
isdn overlap-receiving T302 4000
isdn protocol-emulate network
isdn incoming-voice voice
no cdp enable
interface Serial0/3/1:15
no ip address
encapsulation hdlc
no cdp enable
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
voice-port 0/0/0
voice-port 0/0/1
voice-port 0/0/2
voice-port 0/0/3
voice-port 0/3/0:15
voice-port 0/3/1:15
voice-port 0/2/0
voice-port 0/2/1
voice-port 0/2/2
voice-port 0/2/3
dial-peer voice 5000 pots
destination-pattern 5[1-4]..
no digit-strip
direct-inward-dial
port 0/3/0:15
forward-digits 4
dial-peer voice 4000 voip
destination-pattern 4...
voice-class codec 1
session protocol sipv2
session target ipv4:192.168.20.10
session transport udp
no vad
dial-peer voice 6666 pots
destination-pattern 6666
port 0/2/0
gatekeeper
shutdown
line con 0
logging synchronous
login local
transport output ssh
line aux 0
line vty 0 4
logging synchronous
login local
transport input ssh
scheduler allocate 20000 1000
end
5[1-4]..  -----PAN/PBX ---- E1/QSIG ---- ROUTER------ Elastix------ 4...
r-godden
Beginner
could add the 89 on the router
voice translation-rule 1
rule 1 // /89\1/
voice translation-profile ADD_89
translate called 1
translation-profile outgoing ADD_89
destination-pattern 87
port x/x/x
Ryan,
1) Can you post the full show run for the current status
2) Are all incoming patterns going to start with 89
Alex
Create
Recognize Your Peers
Content for Community-Ad
