03-11-2013 02:35 PM - edited 03-16-2019 04:12 PM
Hi everybody
I have a CME and I configured a trunk group -Label-, I apply the lpcor outgoing XXXX command under the trunk group but when I reload the router, the Lpcor outgoing command is missed, cheking in the startup-config is still there but not in the running-config.
trunk group PSTNLD
hunt-scheme random
trunk group lpcor outgoing Block
trunk group PSTN01800X
hunt-scheme sequential
System image file is "flash:c2900-universalk9-mz.SPA.152-2.T1.bin"
Cisco CISCO2921/K9
best regards
Jose
03-11-2013 03:03 PM
Hi Jose,
There's a known bug for this issue:
CSCtw62027 LPOR trunk group command disappears after reload
There is a script you can configure on the router so that each time it is reloaded the command is added.
Workaround
script configured to add the commands that are lost when the router is reloaded
logging buffered 64000 <---- store the boot log in a memory buffer
interface loopback 100 <---- loopback does not need an IP address
configured
event manager applet AddTrunk
event syslog pattern "Interface Loopback100.* up" period 1
action 1.0 cli command "enable"
action 2.0 cli command "configure terminal"
action 3.0 cli command "trunk group PSTN"
action 4.0 cli command "lpcor outgoing PSTNTrunk"
action 5.0 cli command "end"
action 6.0 cli command "write mem"
action 7.0 syslog msg "trunk group lpcor outgoing PSTNTrunk added"
// so what it does is monitor the status of the Loopback 100, when it goes up the
configuration below is added. The idea is that when the router reloads, the loopback 100
goes up and the trunk group is added.
I know this is not a fix, but you can open a TAC case to see in which IOS version the fix will be available.
Tere.
If you find this post helpful, please rate!
04-10-2013 04:11 PM
i configured the script and is not working.
I hope you can help me
