12-03-2012 03:14 AM - edited 03-16-2019 02:30 PM
Hi voice team,
i´d like to know how to configure a trunk-group in the router with 2 links E1 - R2-Digital,
Attached is the running-config.
Solved! Go to Solution.
12-03-2012 08:45 AM
No worries Thiago, happens to us all :-)
You cant apply it on the voice-port for E1R2 config, else you'll get the same error you got before. The final place you need to apply the trunk group is on the POTS dialpeers. Let me know how it goes.
Harmit.
12-03-2012 09:01 AM
Thiago,
You need to go into the sub config mode for cas-custom 0, like this:
RT-TELEFONIA(config)#controller e1 0/0/0
RT-TELEFONIA(config-controller)#cas-custom 0
RT-TELEFONIA(config-ctrl-cas)#trunk-group ?
WORD Trunk group label
Harmit.
12-03-2012 07:37 AM
Did you try searching for it? Quick Google search reveals this good doc:
http://www.markholloway.com/blog/?p=452
HTH,
Chris
12-03-2012 07:39 AM
Hi, the router doesn't have any serial interface.
Thanks.
12-03-2012 07:48 AM
serial interface is only for PRI circuits, if these are pots lines or E1/T1 CAS circuits then apply trunk group to voice-port.
HTH,
Chris
12-03-2012 07:51 AM
When i applied the trunk-group on voice-port, thats happen:
RT-TELEFONIA(config)#voice-port 0/0/0:0
RT-TELEFONIA(config-voiceport)#trunk-group E1
Error: Failed to add non-analog port to trunk group
Configure in cas-custom mode or serial interface
mode for T1/E1 digital ports and in BRI interface
mode for BRI voice ports
12-03-2012 08:04 AM
Hi Thiago,
Like the error states, for E1R2, trunk groups can ideally be configured in the cas custom mode:
http://www.cisco.com/en/US/tech/tk652/tk653/technologies_tech_note09186a00800942f2.shtml
www.cisco.com/en/US/docs/ios/12_2t/12_2t11/feature/guide/ftgwrepg.html#wp1034848
HTH.
Harmit.
12-03-2012 08:22 AM
The router models is: 2811 and the cas-custom is already configured:
controller E1 0/0/0
framing NO-CRC4
ds0-group 0 timeslots 1-15,17-30 type r2-digital r2-compelled ani
cas-custom 0
country brazil
metering
double-answer
category 2
answer-signal group-b 1
description LINK BRASILTELECOM 1
controller E1 0/0/1
framing NO-CRC4
cas-custom 0
country brazil
metering
double-answer
category 2
description LINK BRASILTELECOM 2
12-03-2012 08:28 AM
Thiago,
I guess you didn't go through the link I gave :-)
E1R2Router(config)#controller E1 0E1R2Router(config-controller)#ds0-group 1 timeslots 2 type r2-digital r2-compelled aniE1R2Router(config-controller)#cas-custom 1E1R2Router(config-ctrl-cas)#?CAS custom commands: alert-wait-time Time to wait for alert indication for incoming R2 calls ani-digits Expected number of ANI digits ani-timeout Timeout for ANI digits answer-guard-time Wait Between Group-B Answer Signal And Line Answer answer-signal Answer signal to be used caller-digits Digits to be collected before requesting CallerID category Category signal country Country Name debounce-time Debounce Timer default Set a command to its defaults disconnect-tone Provide tone to the calling party after sending group B dnis-complete Send I-15 after DNIS digits for dial-out dnis-digits Expected number of DNIS digits exit Exit from cas custom mode groupa-callerid-end Send Group-A Caller ID End invert-abcd invert the ABCD bits before tx and after rx kA kA Signal kd KD Signal metering R2 network is sending metering signal nc-congestion Non Compelled Congestion signal no Negate a command or set its defaults proceed-to-send Suppress proceed-to-send signal for pulsed line signaling release-ack Send Release Acknowledgment to Clear Forward release-guard-time Release Guard Timer request-category DNIS Digits to be collected before requesting category seizure-ack-time Seizure to Acknowledge timer signal-end-to-end Transfer R2 Category and Answer signals end-to-end timer configure timer trunk-group Configure interface to be in a trunk group
unused-abcd Unused ABCD bit values
Did you try this?
Harmit.
12-03-2012 08:40 AM
Oh sorry, i will try to do this,but after applying the trunk on controller, i have to put the trunk-group in the voice-port to?
Thanks.
12-03-2012 08:45 AM
Harmit.
01-14-2016 02:19 AM
Hi Everyone,
I am facing this issue too with a 3925 ISR (C3900e-UNIVERSALK9-M), Version 15.5(1)T.
My config:
trunk group LABEL1
hunt-scheme longest-idle
controller E1 0/1/0
framing NO-CRC4
ds0-group 1 timeslots 1-15,17-31 type r2-digital r2-compelled ani
cas-custom 1
country brazil
metering
category 2
trunk-group LABEL1
controller E1 0/1/1
framing NO-CRC4
cas-custom 1
country brazil use-defaults
metering
category 2
trunk-group LABEL1
controller E1 0/1/2
framing NO-CRC4
cas-custom 1
metering
category 2
trunk-group LABEL1
dial-peer voice 140 pots
description - Mobile Local calls
destination-pattern 09........$
progress_ind alert enable 8
trunkgroup LABEL1
As soon as I set up this config, all my call did not reach the gateway anymore. Does anybody has any idea, I couldn't find anything on google yet!
Any help it's going to be more then welcome!
MC
12-03-2012 08:45 AM
I have another doubt, the " cas-custom 1 " works in brazil to?
12-03-2012 08:50 AM
Thiago,
That was just an example. The syntax for this command is:
R7(config-controller)#cas-custom ?
<0-30> Channel number
The channel number depends on your ds0-group number. I dont see why cas-custom 1 wont work in Brazil.
Harmit.
12-03-2012 08:54 AM
But the router is already configured with "cas-custom 0", and "ds0-group 0" and dont appears the trunk-group option:
RT-TELEFONIA(config-controller)#?
Controller configuration commands:
alarm-trigger ds0 alarm aggregation
cas-custom cas group customization configuration
channel-group Specify the timeslots to channel-group mapping for an
interface
clock Specify the clock source for a DS1 link
description Controller specific description
detect Enable detection of loopback request
ds0 ds0 commands
ds0-group Configure group of timeslots to a particular signaling type
exit Exit from controller configuration mode
framing Specify the type of Framing on a E1 link
guard-timer Guard timer (0-20) for xcsp calls - timer duration and
accept/reject on expiry
help Description of the interactive help system
line-termination Specify the line termination for E1
linecode Specify the line encoding method for a E1 link
loopback Put the entire E1 line into loopback
mode Configure the controller mode
pri-group Configure the specified timeslots for PRI
shutdown Shut down a E1 link (send Blue Alarm)
snmp Modify SNMP controller parameters
tdm-group Configure DS0 group for TDM
12-03-2012 09:01 AM
Thiago,
Harmit.
