Trying to get Brazil dial-peers correct for additional cellular digit
Bill Klosa
I cannot get cellular calls to Sao Paulo to go through. Any insight would be appreciated. ! dial-peer voice 191 pots description Emergency Calling destination-pattern 19. port 0/0/0:1 forward-digits 3 ! dial-peer voice 9191 pots description Emergency Calls with prefix 9 dialed destination-pattern 019. port 0/0/0:1 forward-digits 3 ! dial-peer voice 98 pots description Local calls 8 digit destination-pattern 0[2-9]....... port 0/0/0:1 forward-digits 8 ! dial-peer voice 900 pots description International Calls destination-pattern 000T port 0/0/0:1 prefix 00 ! dial-peer voice 909 pots description Sao Paulo Cellular Calls destination-pattern 043119[6-9]....... progress_ind setup enable 3 progress_ind alert enable 8 port 0/0/0:1 forward-digits all ! dial-peer voice 300 pots description 0300 local-rate dialing destination-pattern 0300....... progress_ind setup enable 3 progress_ind alert enable 8 port 0/0/0:1 forward-digits all ! dial-peer voice 800 pots description 0800 toll-free numbers destination-pattern 0800....... progress_ind setup enable 3 progress_ind alert enable 8 port 0/0/0:1 forward-digits all ! dial-peer voice 801 pots description 0800 toll-free numbers destination-pattern 0800...... progress_ind setup enable 3 progress_ind alert enable 8 port 0/0/0:1 forward-digits all ! dial-peer voice 301 pots description 0300 local-rate dialing destination-pattern 0300...... progress_ind setup enable 3 progress_ind alert enable 8 port 0/0/0:1 forward-digits all ! dial-peer voice 908 pots description Long Distance Calls destination-pattern 0043[1-9].[2-9]....... port 0/0/0:1 forward-digits 13
Nathan Compton
Level 4
Level 4
Is it possible that mobile phone calls to Sao Paulo don't need to go through a long distance carrier?  Are you in the same geographic code as Sao Paulo?
The configuration was correct. Telco did not have the configuration correct on their side.
