Cisco Community Designated VIP Class of 2020
174
Highlighted
Two SIP TRunks to same ISP wth same realm
Hello I have a CUCM connected via SIP Trunk to a CUBE, I need to set two SIP Trunks from the CUBE to the SAME provider.
  But I have only been able to correctly register and establish one because the ISP uses the same realm, and placing the authentication for the second SIP only updates the first one.
 credentials username XXXXXX password 7 XXXXXXXXX realm isp.com
 credentials username YYYYYYY password 7 YYYYYYYY realm isp.com
 authentication username XXXXXX password 7 XXXXXX realm isp.com
 authentication username YYYYYY password 7 YYYYYY realm isp.com (This command only update the first authentication beacuse is the same realm)
 registrar 1 dns:isp.com expires 3600
 registrar 2 dns:isp.comexpires 3600
 sip-server dns:isp.com
How can I do to register the two sip to the same provider with the same realm?
2 REPLIES 2
Hall of Fame Cisco Employee
Have you tried this?
http://www.cisco.com/c/en/us/td/docs/ios-xml/ios/voice/cube/configuration/cube-book/voi-cube-multi-tenants.pdf
java
if this helps, please rate
Yes, the same happens, as it
Yes, the same happens, as it is the same realm only updates me the password of the first ...
Content for Community-Ad
FusionCharts will render here
