Beginner
UC 500 outgoing caller id with two companies
How can i set up an extension to change the outgoing caller id from one company to another before making the outgoing call. They are using sip trunks.
2 REPLIES 2
Re: UC 500 outgoing caller id with two companies
Need little clarification here....
So you have a phone registered with UC/CME, and u want to send
two different caller IDs when dialing out using the same line/button on
that phone? How are you going to differntiate if that oubound call is
from CompanyA or CompanyB when both are using same phone+DN?
A simpler way would be to create two different ephone dns with diff.
dn/name/descp/label etc. and then apply it to two diff. buttons on the
phone. Use proper button on the phone to make resp. outbound call
and callerID shd reflect that.
Highlighted
If I understand it correctly you have UC500 series with CME and you would like to change the calling party number on outgoing calls depending on where the call is going. Let me know if I misunderstood it. And give me an example with a drawing if possible.
You can accomplish this by creating two separate outgoing dialpeers and adding translation rules to them outbound direction. For example:
voice translation-rule 1
rule 1 /match/ /replace/
voice translation-profile
translate calling 1
voice translation-rule 2
translate calling 2
dial-peer voice 100 voip
destination-pattern 7777
session protocol sipv2
session target ipv4:10.1.1.1
translation-profile outgoing
dial-peer voice 101 voip
destination-pattern 8888
session target ipv4:10.1.1.2
Translation rules:
http://www.cisco.com/en/US/partner/tech/tk652/tk90/technologies_tech_note09186a0080325e8e.shtml
Dialpeers:
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_tech_note09186a008010ae1c.shtml
Let me know if you have any questions.
Best regards,
Apor
Content for Community-Ad
August's Community Spotlight Awards
