07-04-2014 12:35 PM - edited 03-16-2019 11:18 PM
Dear all,
I would like to add an additional VIC 4 FXO card in UC 540 expansion slot. Can I add additional VIC 4 FXO card without adding DSP modules.?
Same device I have to create auto attendant system. What are the licence required for auto attendant feature ?
Products details are given below
UC 540 VIC 4 FXO CARD ADDITION IN VIC EXPANSION SLOT
Cisco UC540W-FXO-K9 (MPC8358) processor (revision 0x100) with 235520K/26624K bytes of memory.
MPC8358 CPU Rev: Part Number 0x804A, Revision ID 0x20
30 User Licenses
10 FastEthernet interfaces
2 terminal lines
1 Virtual Private Network (VPN) Module
4 Voice FXO interfaces
4 Voice FXS interfaces
1 Voice MoH interface
1 802.11 Radio
1 cisco service engine(s)
128K bytes of non-volatile configuration memory.
250880K bytes of ATA CompactFlash (Read/Write)
Ajay Jose K
Solved! Go to Solution.
07-04-2014 06:35 PM
Hi ajay1komban,
You don´t need a license for auto attendant system and for the expansion VIC slot you have to consider the Conference and Transcoding design, you can check the total number of session from this link:
http://www.cisco.com/c/en/us/products/collateral/unified-communications/unity-express/C78-557768-00_540_platform_reference_guide_DS_v2a.html
If it was useful please rate.
Regards.
07-04-2014 10:12 PM
Yes you can use auto attendant capabilities from CME without CUE, you need to use it with scripts, if you have doubts about it please let me know.
Regards.
07-04-2014 06:35 PM
Hi ajay1komban,
Regards.
07-04-2014 07:21 PM
Hi Emmanuel Valdez,
Thank you for your support.
We are not using conference and Transcoding in our network.We have built in VIC 4 FXO and VIC 4 FXS in our system.When I go through show dsp farm
Dspfarm Profile Configuration
Profile ID = 1, Service = CONFERENCING, Resource ID = 1
Profile Description : DO NOT MODIFY, active CCA conference profile - CCA2.0 codec711
Profile Service Mode : Non Secure
Profile Admin State : UP
Profile Operation State : ACTIVE
Application : SCCP Status : ASSOCIATED
Resource Provider : FLEX_DSPRM Status : UP
Number of Resource Configured : 4
Number of Resource Available : 4
Maximum conference participants : 32
Codec Configuration: num_of_codecs:2
Codec : g711alaw, Maximum Packetization Period : 30 , Transcoder: Not Required
Codec : g711ulaw, Maximum Packetization Period : 30 , Transcoder: Not Required
SLOT DSP VERSION STATUS CHNL USE TYPE RSC_ID BRIDGE_ID PKTS_TXED PKTS_RXED
0 3 28.3.5 UP N/A FREE conf 1 - - -
0 4 28.3.5 UP N/A FREE conf 1 - - -
Total number of DSPFARM DSP channel(s) 4
Can I use auto attendant system with out CUE ?
Thanks&Regards,
Ajay Jose K
07-04-2014 10:12 PM
Regards.
