UC upgrade question ? help
gssnettech
Dear all
I have a question , our customer want to upgrade their callmanager and unity connection from 7.1.5 to 8.5.1 then order the upgrade package and feature license from cisco , now i recevied the software disk but i can not upgrade unity connection to new version and  the installing log display this server does not support this version , but the callmanager can upgrade to 8.5.1 in normally so the callmanager and unity connection using the same  old version are 7.1.5.10000-12   the new version is 8.5.1.10000-26
otherwise, i want to install new subscriber of  unity connection using 8.5.1 disk ,but i can not found unity connection on select option
does anyone can help me to solve this issue?  thanks
Jaime Valencia
During the install process HW is validated, if you do not see CUC as an option that means the HW
a) might not be supported
b) might be supported but HDD/RAM upgrade is required.
Have you already validated your HW is compatible in the CUC HW compatibility list????
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Here's the document java is referencing: http://www.cisco.com/en/US/partner/docs/voice_ip_comm/connection/8x/supported_platforms/8xcucspl.html#wp771057
Be sure that you have at least 4GB of memory and 146GB of disk (I suggest 300GB or more) installed.
