2151
UC500 Automatic Reboot
Hi All
I would like to have a UC520 automatically reboot (by applying some command on configuration) after every 2 or month continues running and set a time and date frame.
because we have few customers with UC500, UC520, after 3 months they cant make any calls. so we have to do a reboot to solve this problem.
eventhough they have latest firmware installed.
any idea. is it possible.
thanks
shameer
1 ACCEPTED SOLUTION
barry
Rising star
Hi Shameer
You should be able to use the CLI reload command to do this:
Barry#reload ?
  /noverify  Don't verify file signature before reload.
  /verify    Verify file signature before reload.
  at         Reload at a specific time/date
  cancel     Cancel pending reload
  in         Reload after a time interval
  reason     Reload reason
  warm       Reload should be warm
Check out the "at" and "in" options.
This will only schedule a single reload - so you will need to issue the command again after 2-3 months once each unit has reloaded.
HTH. Barry
4 REPLIES 4
barry
Rising star
Hi Shameer
Barry#reload ?
HTH. Barry
Hi Barry
Thanks for your quick response.
ya its only for single reboot.
I need something for every 3 month, so its not possible on UC then
shameer
Hi Shameer
I haven't got access to a UC520 where I am at the moment, but it may be possible.
If the UC520 supports kron, then you could create a kron job that executes the appropriate "reload in" command on system startup.
Another option, if you have IP acess to each of the UC520s is to use SNMP to issue the reload from an SNMP monitoring / management station like Solarwinds.
HTH. Barry
Q. How can I reload a router with use of SNMP?OLD-CISCO-TS-MIB tsMsgSend OBJECT-TYPE -- FROM OLD-CISCO-TS-MIB SYNTAX Integer { nothing(1), reload(2), messagedone(3), abort(4) } MAX-ACCESS read-write STATUS Mandatory DESCRIPTION "Sends the message. The value determines what to do after the message has completed." ::= { iso(1) org(3) dod(6) internet(1) private(4) enterprises(1) cisco(9) local(2) lts(9) 9 }
A. Follow this procedure:
tsMsgSend = .1.3.6.1.4.1.9.2.9.9 from the
On the Cisco router, you must set these commands to support the reload command:
snmp-server community private RW
snmp-server system-shutdown
This example reloads the router with IP address 10.16.99.55:
# ./snmpset 10.16.99.55 private .1.3.6.1.4.1.9.2.9.9.0 i 2
!--- This is an explanation of the variables that this command uses.
          10.16.99.55 = ip address of your router
               private = R/W SNMP Community string of your router
.1.3.6.1.4.1.9.2.9.9.0 = tsMsgSend SNMP MIB OID
                     i = Integer as defined SYNTAX in the MIB
                     2 = reload command as defined in the MIB
Hi Shameer
HTH. Barry
Create
Recognize Your Peers
Content for Community-Ad
