09-15-2011 02:20 AM - edited 03-16-2019 07:00 AM
Hi All
I would like to have a UC520 automatically reboot (by applying some command on configuration) after every 2 or month continues running and set a time and date frame.
because we have few customers with UC500, UC520, after 3 months they cant make any calls. so we have to do a reboot to solve this problem.
eventhough they have latest firmware installed.
any idea. is it possible.
thanks
shameer
Solved! Go to Solution.
09-15-2011 02:25 AM
Hi Shameer
You should be able to use the CLI reload command to do this:
Barry#reload ?
/noverify Don't verify file signature before reload.
/verify Verify file signature before reload.
at Reload at a specific time/date
cancel Cancel pending reload
in Reload after a time interval
reason Reload reason
warm Reload should be warm
Check out the "at" and "in" options.
This will only schedule a single reload - so you will need to issue the command again after 2-3 months once each unit has reloaded.
HTH. Barry
09-15-2011 02:25 AM
Hi Shameer
Barry#reload ?
HTH. Barry
09-15-2011 02:46 AM
Hi Barry
Thanks for your quick response.
ya its only for single reboot.
I need something for every 3 month, so its not possible on UC then
shameer
09-15-2011 03:26 AM
Hi Shameer
I haven't got access to a UC520 where I am at the moment, but it may be possible.
If the UC520 supports kron, then you could create a kron job that executes the appropriate "reload in" command on system startup.
Another option, if you have IP acess to each of the UC520s is to use SNMP to issue the reload from an SNMP monitoring / management station like Solarwinds.
HTH. Barry
A. Follow this procedure:
tsMsgSend = .1.3.6.1.4.1.9.2.9.9 from theOn the Cisco router, you must set these commands to support the reload command:
snmp-server community private RW snmp-server system-shutdownThis example reloads the router with IP address 10.16.99.55:
# ./snmpset 10.16.99.55 private .1.3.6.1.4.1.9.2.9.9.0 i 2 !--- This is an explanation of the variables that this command uses. 10.16.99.55 = ip address of your router private = R/W SNMP Community string of your router .1.3.6.1.4.1.9.2.9.9.0 = tsMsgSend SNMP MIB OID i = Integer as defined SYNTAX in the MIB 2 = reload command as defined in the MIB
09-15-2011 03:30 AM
Hi Shameer
HTH. Barry
