05-06-2011 02:43 AM - edited 03-16-2019 04:50 AM
I've a UC560 with a few 7911 phones connected to it. I want to change default logo (Cisco logo) with our comapny logo.
I've created Destops/95x34x1 directory in flash:. I've upload List.xml file and our company logos (in good format)to this directory.
When I go to phone,user preferences, background, it give me the next error. 'selections unavailable'.
If I debug tftp events on UC560, it shows the next error Looking for Desktops/95x34x1/List.xml
Any idea
Regards.
Luis BLanc
MEINSA SISTEMAS, S.L.
Solved! Go to Solution.
05-06-2011 05:11 AM
You definitely haven't got a tftp-server file for your List.xml
Could you try (one more time)
tftp-server flash:Desktops/95x34x1/List.xml
and if that fails, try
no tftp-server flash:Desktops/95x34x1/List.xml
And then see if the command appears..?
Barry
05-06-2011 03:33 AM
Hi Luis
Is this a typo?
Barry
05-06-2011 03:38 AM
Yes, it is a mistake.
The correct directory is Desktops/95x34x1 in flash:
05-06-2011 03:49 AM
Hi Luis
You're probably missing the tftp-server command to serve out the file.
However, what I normally do is use the "alias" command on the tftp command so I don't have to create horrible directory structures on the router flash.
Example:
tftp-server flash:logo.png alias Desktops/95x34x1/logo.png
tftp-server flash:List.xml alias Desktops/95x34x1/List.xml
This allows me to store the logo and List.xml file in the root directory of the flash.
However, you will need tftp-server commands to serve out the content, regardless of where you store them.
Barry
05-06-2011 04:00 AM
Thanks Barry,
but when I use tftp-server command to serve out the file, it shows "File with same name already being served".
Luis
05-06-2011 04:02 AM
Hi Luis
I would try clearing out the existing tftp-server commands with the "no tftp-server" command first for each entry and then recreate them.
Barry
05-06-2011 04:03 AM
05-06-2011 04:07 AM
could you also post output from "show run | i tftp"?
Thanks.
05-06-2011 04:11 AM
05-06-2011 04:19 AM
Ok... I see the problem.
Do:
no tftp-server flash:logo.png alias Desktops/95x34x1/logo.png
(this was only me illustrating loading a logo file in the root of the router's flash)
tftp-server flash:Desktops/95x34x1/Meinsalogo.png
tftp-server flash:Desktops/95x34x1/TN-Meinsalogo.png
Hopefully that should be it.
Barry
05-06-2011 04:31 AM
No luck.
This is the output whe I execute your commands
UC_560(config)#tftp-server flash:Desktops/95x34x1/List.xml
UC_560(config)#tftp-server flash:Desktops/95x34x1/Meinsalogo.png
UC_560(config)#tftp-server flash:Desktops/95x34x1/TN-Meinsalogo.png
Are there any way to recreate these files to tftp server?
Luis
05-06-2011 04:35 AM
that doesn't make much sense... As in your "show run" output those files were not being served as far as I
could see.
Could you copy and paste the output from "show run | i tftp" again here..? Your ZIP files keep crashing my browser (I'm stupidly using IE9 so it's my own fault) - so if you could just copy and paste that would be great.
Barry
05-06-2011 04:45 AM
Barry
I've solved the problem for PNG files.
Now the problem is only with List.xml.
This is the output you are requesting.
C_560#show run | i tftp
ip inspect name SDM_LOW tftp
ip tftp source-interface Vlan90
tftp-server flash:/phones/521_524/cp524g-8-1-17.bin alias cp524g-8-1-17.bin
tftp-server flash:/phones/7906_7911/apps11.8-5-4TH1-6.sbn alias apps11.8-5-4TH1-6.sbn
tftp-server flash:/phones/7906_7911/cnu11.8-5-4TH1-6.sbn alias cnu11.8-5-4TH1-6.sbn
tftp-server flash:/phones/7906_7911/cvm11sccp.8-5-4TH1-6.sbn alias cvm11sccp.8-5-4TH1-6.sbn
tftp-server flash:/phones/7906_7911/dsp11.8-5-4TH1-6.sbn alias dsp11.8-5-4TH1-6.sbn
tftp-server flash:/phones/7906_7911/jar11sccp.8-5-4TH1-6.sbn alias jar11sccp.8-5-4TH1-6.sbn
tftp-server flash:/phones/7906_7911/SCCP11.8-5-4S.loads alias SCCP11.8-5-4S.loads
tftp-server flash:/phones/7906_7911/term06.default.loads alias term06.default.loads
tftp-server flash:/phones/7906_7911/term11.default.loads alias term11.default.loads
tftp-server flash:/phones/7931/apps31.8-5-4TH1-6.sbn alias apps31.8-5-4TH1-6.sbn
tftp-server flash:/phones/7931/cnu31.8-5-4TH1-6.sbn alias cnu31.8-5-4TH1-6.sbn
tftp-server flash:/phones/7931/cvm31sccp.8-5-4TH1-6.sbn alias cvm31sccp.8-5-4TH1-6.sbn
tftp-server flash:/phones/7931/dsp31.8-5-4TH1-6.sbn alias dsp31.8-5-4TH1-6.sbn
tftp-server flash:/phones/7931/jar31sccp.8-5-4TH1-6.sbn alias jar31sccp.8-5-4TH1-6.sbn
tftp-server flash:/phones/7931/SCCP31.8-5-4S.loads alias SCCP31.8-5-4S.loads
tftp-server flash:/phones/7931/term31.default.loads alias term31.default.loads
tftp-server flash:/phones/7937/apps37sccp.1-3-4-0.bin alias apps37sccp.1-3-4-0.bin
tftp-server flash:/phones/7945_7965/apps45.8-5-4TH1-6.sbn alias apps45.8-5-4TH1-6.sbn
tftp-server flash:/phones/7945_7965/cnu45.8-5-4TH1-6.sbn alias cnu45.8-5-4TH1-6.sbn
tftp-server flash:/phones/7945_7965/cvm45sccp.8-5-4TH1-6.sbn alias cvm45sccp.8-5-4TH1-6.sbn
tftp-server flash:/phones/7945_7965/dsp45.8-5-4TH1-6.sbn alias dsp45.8-5-4TH1-6.sbn
tftp-server flash:/phones/7945_7965/jar45sccp.8-5-4TH1-6.sbn alias jar45sccp.8-5-4TH1-6.sbn
tftp-server flash:/phones/7945_7965/SCCP45.8-5-4S.loads alias SCCP45.8-5-4S.loads
tftp-server flash:/phones/7945_7965/term45.default.loads alias term45.default.loads
tftp-server flash:/phones/7945_7965/term65.default.loads alias term65.default.loads
tftp-server flash:/ringtones/Analog1.raw alias Analog1.raw
tftp-server flash:/ringtones/Analog2.raw alias Analog2.raw
tftp-server flash:/ringtones/AreYouThere.raw alias AreYouThere.raw
tftp-server flash:/ringtones/DistinctiveRingList.xml alias DistinctiveRingList.xml
tftp-server flash:/ringtones/RingList.xml alias RingList.xml
tftp-server flash:/ringtones/AreYouThereF.raw alias AreYouThereF.raw
tftp-server flash:/ringtones/Bass.raw alias Bass.raw
tftp-server flash:/ringtones/CallBack.raw alias CallBack.raw
tftp-server flash:/ringtones/Chime.raw alias Chime.raw
tftp-server flash:/ringtones/Classic1.raw alias Classic1.raw
tftp-server flash:/ringtones/Classic2.raw alias Classic2.raw
tftp-server flash:/ringtones/ClockShop.raw alias ClockShop.raw
tftp-server flash:/ringtones/Drums1.raw alias Drums1.raw
tftp-server flash:/ringtones/Drums2.raw alias Drums2.raw
tftp-server flash:/ringtones/FilmScore.raw alias FilmScore.raw
tftp-server flash:/ringtones/HarpSynth.raw alias HarpSynth.raw
tftp-server flash:/ringtones/Jamaica.raw alias Jamaica.raw
tftp-server flash:/ringtones/KotoEffect.raw alias KotoEffect.raw
tftp-server flash:/ringtones/MusicBox.raw alias MusicBox.raw
tftp-server flash:/ringtones/Piano1.raw alias Piano1.raw
tftp-server flash:/ringtones/Piano2.raw alias Piano2.raw
tftp-server flash:/ringtones/Pop.raw alias Pop.raw
tftp-server flash:/ringtones/Pulse1.raw alias Pulse1.raw
tftp-server flash:/ringtones/Ring1.raw alias Ring1.raw
tftp-server flash:/ringtones/Ring2.raw alias Ring2.raw
tftp-server flash:/ringtones/Ring3.raw alias Ring3.raw
tftp-server flash:/ringtones/Ring4.raw alias Ring4.raw
tftp-server flash:/ringtones/Ring5.raw alias Ring5.raw
tftp-server flash:/ringtones/Ring6.raw alias Ring6.raw
tftp-server flash:/ringtones/Ring7.raw alias Ring7.raw
tftp-server flash:/ringtones/Sax1.raw alias Sax1.raw
tftp-server flash:/ringtones/Sax2.raw alias Sax2.raw
tftp-server flash:/ringtones/Vibe.raw alias Vibe.raw
tftp-server flash:/Desktops/CampusNight.png
tftp-server flash:/Desktops/TN-CampusNight.png
tftp-server flash:/Desktops/CiscoFountain.png
tftp-server flash:/Desktops/TN-CiscoFountain.png
tftp-server flash:/Desktops/CiscoLogo.png
tftp-server flash:/Desktops/TN-CiscoLogo.png
tftp-server flash:/Desktops/Fountain.png
tftp-server flash:/Desktops/TN-Fountain.png
tftp-server flash:/Desktops/MorroRock.png
tftp-server flash:/Desktops/TN-MorroRock.png
tftp-server flash:/Desktops/NantucketFlowers.png
tftp-server flash:/Desktops/TN-NantucketFlowers.png
tftp-server flash:/bacdprompts/en_bacd_allagentsbusy.au alias en_bacd_allagentsbusy.au
tftp-server flash:/bacdprompts/en_bacd_disconnect.au alias en_bacd_disconnect.au
tftp-server flash:/bacdprompts/en_bacd_enter_dest.au alias en_bacd_enter_dest.au
tftp-server flash:/bacdprompts/en_bacd_invalidoption.au alias en_bacd_invalidoption.au
tftp-server flash:/bacdprompts/en_bacd_music_on_hold.au alias en_bacd_music_on_hold.au
tftp-server flash:/bacdprompts/en_bacd_options_menu.au alias en_bacd_options_menu.au
tftp-server flash:/bacdprompts/en_bacd_welcome.au alias en_bacd_welcome.au
tftp-server flash:/bacdprompts/en_bacd_xferto_operator.au alias en_bacd_xferto_operator.au
tftp-server flash:Desktops/320x212x16/List.xml
Luis
05-06-2011 05:11 AM
Barry
05-06-2011 05:15 AM
Thanks Barry
Problem was solved.
I've a duplicate entry served as List.xml
Finally, I've been able to remove it to be served from tftp-server, and I've been able to publish the correct entry.
Now I can select our company logo from our phones.
Luis.
PS. How can I give you points for your help?, and how can I close the thread?
