UC500-Background LOGO 7911
lblanc
I've a UC560 with a few 7911 phones connected to it. I want to change default logo (Cisco logo) with our comapny logo.
I've created Destops/95x34x1 directory in flash:. I've upload List.xml file and our company logos (in good format)to this directory.
When I go to phone,user preferences, background, it give me the next error. 'selections unavailable'.
If I debug tftp events on UC560, it shows the next error Looking for Desktops/95x34x1/List.xml
Any idea
Regards.
Luis BLanc
MEINSA SISTEMAS, S.L.
You definitely haven't got a tftp-server file for your List.xml
Could you try (one more time)
tftp-server flash:Desktops/95x34x1/List.xml
and if that fails, try
no tftp-server flash:Desktops/95x34x1/List.xml
And then see if the command appears..?
Barry
16 Replies 16
barry
Level 7
Level 7
Hi Luis
Is this a typo?
Barry
Yes, it is a mistake.
The correct directory is Desktops/95x34x1 in flash:
Hi Luis
You're probably missing the tftp-server command to serve out the file.
However, what I normally do is use the "alias" command on the tftp command so I don't have to create horrible directory structures on the router flash.
Example:
tftp-server flash:logo.png alias Desktops/95x34x1/logo.png
tftp-server flash:List.xml alias Desktops/95x34x1/List.xml
This allows me to store the logo and List.xml file in the root directory of the flash.
However, you will need  tftp-server commands to serve out the content, regardless of where you store them.
Barry
Thanks Barry,
but when I use tftp-server command to serve out the file, it shows "File with same name already being served".
Luis
Hi Luis
I would try clearing out the existing tftp-server commands with the "no tftp-server" command first for each entry and then recreate them.
Barry
I've attached show flash: all command from my UC560
Luis
could you also post output from "show run | i tftp"?
Thanks.
Attached....
Ok... I see the problem.
Do:
no tftp-server flash:logo.png alias Desktops/95x34x1/logo.png
(this was only me illustrating loading a logo file in the root of the router's flash)
tftp-server flash:Desktops/95x34x1/Meinsalogo.png
tftp-server flash:Desktops/95x34x1/TN-Meinsalogo.png
Hopefully that should be it.
Barry
No luck.
This is the output whe I execute your commands
UC_560(config)#tftp-server flash:Desktops/95x34x1/List.xml
UC_560(config)#tftp-server flash:Desktops/95x34x1/Meinsalogo.png
UC_560(config)#tftp-server flash:Desktops/95x34x1/TN-Meinsalogo.png
Are there any way to recreate these files to tftp server?
Luis
that doesn't make much sense... As in your "show run" output those files were not being served as far as I
could see.
Could you copy and paste the output from "show run | i tftp" again here..? Your ZIP files keep crashing my browser (I'm stupidly using IE9 so it's my own fault) - so if you could just copy and paste that would be great.
Barry
Barry
I've solved the problem for PNG files.
Now the problem is only with List.xml.
This is the output you are requesting.
C_560#show run | i tftp
ip inspect name SDM_LOW tftp
ip tftp source-interface Vlan90
tftp-server flash:/phones/521_524/cp524g-8-1-17.bin alias cp524g-8-1-17.bin
tftp-server flash:/phones/7906_7911/apps11.8-5-4TH1-6.sbn alias apps11.8-5-4TH1-6.sbn
tftp-server flash:/phones/7906_7911/cnu11.8-5-4TH1-6.sbn alias cnu11.8-5-4TH1-6.sbn
tftp-server flash:/phones/7906_7911/cvm11sccp.8-5-4TH1-6.sbn alias cvm11sccp.8-5-4TH1-6.sbn
tftp-server flash:/phones/7906_7911/dsp11.8-5-4TH1-6.sbn alias dsp11.8-5-4TH1-6.sbn
tftp-server flash:/phones/7906_7911/jar11sccp.8-5-4TH1-6.sbn alias jar11sccp.8-5-4TH1-6.sbn
tftp-server flash:/phones/7906_7911/SCCP11.8-5-4S.loads alias SCCP11.8-5-4S.loads
tftp-server flash:/phones/7906_7911/term06.default.loads alias term06.default.loads
tftp-server flash:/phones/7906_7911/term11.default.loads alias term11.default.loads
tftp-server flash:/phones/7931/apps31.8-5-4TH1-6.sbn alias apps31.8-5-4TH1-6.sbn
tftp-server flash:/phones/7931/cnu31.8-5-4TH1-6.sbn alias cnu31.8-5-4TH1-6.sbn
tftp-server flash:/phones/7931/cvm31sccp.8-5-4TH1-6.sbn alias cvm31sccp.8-5-4TH1-6.sbn
tftp-server flash:/phones/7931/dsp31.8-5-4TH1-6.sbn alias dsp31.8-5-4TH1-6.sbn
tftp-server flash:/phones/7931/jar31sccp.8-5-4TH1-6.sbn alias jar31sccp.8-5-4TH1-6.sbn
tftp-server flash:/phones/7931/SCCP31.8-5-4S.loads alias SCCP31.8-5-4S.loads
tftp-server flash:/phones/7931/term31.default.loads alias term31.default.loads
tftp-server flash:/phones/7937/apps37sccp.1-3-4-0.bin alias apps37sccp.1-3-4-0.bin
tftp-server flash:/phones/7945_7965/apps45.8-5-4TH1-6.sbn alias apps45.8-5-4TH1-6.sbn
tftp-server flash:/phones/7945_7965/cnu45.8-5-4TH1-6.sbn alias cnu45.8-5-4TH1-6.sbn
tftp-server flash:/phones/7945_7965/cvm45sccp.8-5-4TH1-6.sbn alias cvm45sccp.8-5-4TH1-6.sbn
tftp-server flash:/phones/7945_7965/dsp45.8-5-4TH1-6.sbn alias dsp45.8-5-4TH1-6.sbn
tftp-server flash:/phones/7945_7965/jar45sccp.8-5-4TH1-6.sbn alias jar45sccp.8-5-4TH1-6.sbn
tftp-server flash:/phones/7945_7965/SCCP45.8-5-4S.loads alias SCCP45.8-5-4S.loads
tftp-server flash:/phones/7945_7965/term45.default.loads alias term45.default.loads
tftp-server flash:/phones/7945_7965/term65.default.loads alias term65.default.loads
tftp-server flash:/ringtones/Analog1.raw alias Analog1.raw
tftp-server flash:/ringtones/Analog2.raw alias Analog2.raw
tftp-server flash:/ringtones/AreYouThere.raw alias AreYouThere.raw
tftp-server flash:/ringtones/DistinctiveRingList.xml alias DistinctiveRingList.xml
tftp-server flash:/ringtones/RingList.xml alias RingList.xml
tftp-server flash:/ringtones/AreYouThereF.raw alias AreYouThereF.raw
tftp-server flash:/ringtones/Bass.raw alias Bass.raw
tftp-server flash:/ringtones/CallBack.raw alias CallBack.raw
tftp-server flash:/ringtones/Chime.raw alias Chime.raw
tftp-server flash:/ringtones/Classic1.raw alias Classic1.raw
tftp-server flash:/ringtones/Classic2.raw alias Classic2.raw
tftp-server flash:/ringtones/ClockShop.raw alias ClockShop.raw
tftp-server flash:/ringtones/Drums1.raw alias Drums1.raw
tftp-server flash:/ringtones/Drums2.raw alias Drums2.raw
tftp-server flash:/ringtones/FilmScore.raw alias FilmScore.raw
tftp-server flash:/ringtones/HarpSynth.raw alias HarpSynth.raw
tftp-server flash:/ringtones/Jamaica.raw alias Jamaica.raw
tftp-server flash:/ringtones/KotoEffect.raw alias KotoEffect.raw
tftp-server flash:/ringtones/MusicBox.raw alias MusicBox.raw
tftp-server flash:/ringtones/Piano1.raw alias Piano1.raw
tftp-server flash:/ringtones/Piano2.raw alias Piano2.raw
tftp-server flash:/ringtones/Pop.raw alias Pop.raw
tftp-server flash:/ringtones/Pulse1.raw alias Pulse1.raw
tftp-server flash:/ringtones/Ring1.raw alias Ring1.raw
tftp-server flash:/ringtones/Ring2.raw alias Ring2.raw
tftp-server flash:/ringtones/Ring3.raw alias Ring3.raw
tftp-server flash:/ringtones/Ring4.raw alias Ring4.raw
tftp-server flash:/ringtones/Ring5.raw alias Ring5.raw
tftp-server flash:/ringtones/Ring6.raw alias Ring6.raw
tftp-server flash:/ringtones/Ring7.raw alias Ring7.raw
tftp-server flash:/ringtones/Sax1.raw alias Sax1.raw
tftp-server flash:/ringtones/Sax2.raw alias Sax2.raw
tftp-server flash:/ringtones/Vibe.raw alias Vibe.raw
tftp-server flash:/Desktops/CampusNight.png
tftp-server flash:/Desktops/TN-CampusNight.png
tftp-server flash:/Desktops/CiscoFountain.png
tftp-server flash:/Desktops/TN-CiscoFountain.png
tftp-server flash:/Desktops/CiscoLogo.png
tftp-server flash:/Desktops/TN-CiscoLogo.png
tftp-server flash:/Desktops/Fountain.png
tftp-server flash:/Desktops/TN-Fountain.png
tftp-server flash:/Desktops/MorroRock.png
tftp-server flash:/Desktops/TN-MorroRock.png
tftp-server flash:/Desktops/NantucketFlowers.png
tftp-server flash:/Desktops/TN-NantucketFlowers.png
tftp-server flash:/bacdprompts/en_bacd_allagentsbusy.au alias en_bacd_allagentsbusy.au
tftp-server flash:/bacdprompts/en_bacd_disconnect.au alias en_bacd_disconnect.au
tftp-server flash:/bacdprompts/en_bacd_enter_dest.au alias en_bacd_enter_dest.au
tftp-server flash:/bacdprompts/en_bacd_invalidoption.au alias en_bacd_invalidoption.au
tftp-server flash:/bacdprompts/en_bacd_music_on_hold.au alias en_bacd_music_on_hold.au
tftp-server flash:/bacdprompts/en_bacd_options_menu.au alias en_bacd_options_menu.au
tftp-server flash:/bacdprompts/en_bacd_welcome.au alias en_bacd_welcome.au
tftp-server flash:/bacdprompts/en_bacd_xferto_operator.au alias en_bacd_xferto_operator.au
tftp-server flash:Desktops/320x212x16/List.xml
Luis
Barry
Thanks Barry
Problem was solved.
I've a duplicate entry served as List.xml
Finally, I've been able to remove it to be served from tftp-server, and I've been able to publish the correct entry.
Now I can select our company logo from our phones.
Luis.
PS. How can I give you points for your help?, and how can I close the thread?
