10-07-2015 08:28 AM - last edited on 03-25-2019 08:36 PM by ciscomoderator
I would like to know if cbarge function is supported over PSTN trunks. The router is UC540.
It's working right now on my SIP Trunk but my client want to switch to PSTN trunks.
I would like to know if the cbarge function will still be available and support a conference over PSTN trunk.
Thanks for your help,
Simon
Solved! Go to Solution.
10-08-2015 02:11 AM
Hi Simon,
cBarge does have the capability to handle a call involving a PSTN caller.
Manish
- Do rate helpful posts -
10-08-2015 02:11 AM
Hi Simon,
Manish
10-08-2015 05:57 AM
Thanks for the fast answer Manish,
I just want to make sure if this work if there is no SIP Trunks at all. There will be only PSTN lines plugged into the FXO's ports.
Thanks for your help again
10-15-2015 06:21 AM
Hi Manish,
I finally tested it and it works.
With no SIP Trunk, only FXO PSTN lines, UC500 series router can handle Cbarge.
