UC520 - Inbound Calls Don't Work. Outbound Works Fine
ReidJones
We are in the midst of switching from one ISP to another.  I received the router and need to put it in front of the UC520.  My only problem is that inbound calls aren't working.  I ran the logs and found the following error.  Is there an easy way to fix this?
Thanks!
508123: Feb  6 21:27:39.083: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 400 Bad Request - 'Invalid Host'
Via: SIP/2.0/UDP 67.205.74.187:5060;branch=z9hG4bK1b465d94;rport
From: "OTTAWA, ON" <sip:9051234444@67.205.74.187>;tag=as114d9064
To: <sip:4161234567@70.11.54.125>;tag=AC65B1A0-959
Date: Tue, 07 Feb 2017 02:27:39 GMT
Call-ID: 3c38a49e18e06e726292e7631d3d900f@67.205.74.187:5060
CSeq: 102 INVITE
Allow-Events: telephone-event
Reason: Q.850;cause=100
Server: Cisco-SIPGateway/IOS-12.x
Content-Length: 0
508124: Feb  6 21:27:39.183: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 102 INVITE
Content-Length: 0
508125: Feb  6 21:27:39.187: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:4161234567@70.11.54.125 SIP/2.0
Max-Forwards: 70
Contact: <sip:9051234444@67.205.74.187:5060>
CSeq: 102 ACK
User-Agent: voip.ms
Content-Length: 0
508126: Feb  6 21:27:57.092: //130325/000000000000/SIP/Msg/ccsipDisplayMsg:
Sent:
OPTIONS sip:montreal2.voip.ms:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.2.13:5060;branch=z9hG4bK36BB411EF
To: <sip:montreal2.voip.ms>
Date: Tue, 07 Feb 2017 02:27:57 GMT
Call-ID: DEFAB269-EC1311E6-99CDB6DD-2E5C7378@montreal2.voip.ms
User-Agent: Cisco-SIPGateway/IOS-12.x
Max-Forwards: 70
CSeq: 101 OPTIONS
Contact: <sip:192.168.2.13:5060>
Content-Length: 0
508127: Feb  6 21:27:57.100: //130325/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 192.168.2.13:5060;branch=z9hG4bK36BB411EF;received=70.11.54.125;rport=60527
To: <sip:montreal2.voip.ms>;tag=as62836686
CSeq: 101 OPTIONS
Server: voip.ms
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY, INFO, PUBLISH, MESSAGE
Supported: replaces, timer
Contact: <sip:67.205.74.187:5060>
Accept: application/sdp
Content-Length: 0
7 Replies 7
Brandon Buffin
What version of IOS? Check the following link regarding toll fraud prevention.
http://www.cisco.com/c/en/us/support/docs/voice/call-routing-dial-plans/112083-tollfraud-ios.html
Try adding the following commands to allow this host:
voice service voip
ip address trusted list
ipv4 67.205.74.187
Brandon
The IOS Version is 15.1(4)M5-ADV-IP-SERV-CRYPTO.
I checked the config and am already showing that command is entered.  Should I be adding 70.11.54.125 to the trusted list?
voice service voip
  ipv4 67.205.74.187
Yes, add this address as well. Is this the address of your ISP's edge router?
Thats the IP address of the router supplied to by the ISP (in front of UC520).
Reid,
From the logs it appears that the IP address
70.11.54.125)
that the inbound call is sent to doesnt not exist on the router.
Do you have this host IP configued on any of your interface? Are you using NAT? Pleas epost the full debug ccsip message
Please rate all useful posts
I have a Bell / Sagecom router hooked up to our new Fiber connection.  Behind that I have our UC520 that we've used for years.  I changed the internet configuration on the UC520 from pppoe to DCHP.
The full debug is below:
--------------------------show logging--------------------------
Syslog logging: enabled (0 messages dropped, 3 messages rate-limited, 10 flushes, 0 overruns, xml disabled, filtering disabled)
No Active Message Discriminator.
No Inactive Message Discriminator.
    Console logging: disabled
    Monitor logging: disabled
    Buffer logging:  level debugging, 66 messages logged, xml disabled,
                    filtering disabled
    Exception Logging: size (4096 bytes)
    Count and timestamp logging messages: disabled
    Persistent logging: disabled
No active filter modules.
    Trap logging: level informational, 9617 message lines logged
        Logging Source-Interface:       VRF Name:
Log Buffer (1000000 bytes):
010403: Feb  7 16:11:31.636: %SEC-6-IPACCESSLOGP: list 105 denied tcp 220.162.92.43(49132) -> 169.1.1.1(6789), 1 packet
010404: Feb  7 16:11:32.196: %SYS-5-CONFIG_I: Configured from console by Reid on vty0 (192.168.10.33)
010405: Feb  7 16:11:41.429: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:6131234567@70.11.54.125 SIP/2.0
Via: SIP/2.0/UDP 67.205.74.187:5060;branch=z9hG4bK3298a5e1;rport
Max-Forwards: 70
From: "OTTAWA, ON" <sip:6139876543@67.205.74.187>;tag=as10f6ebf2
To: <sip:6131234567@70.11.54.125>
Contact: <sip:6139876543@67.205.74.187:5060>
Call-ID: 3ec7e39d6a494433647ff4161b9dbc90@67.205.74.187:5060
CSeq: 102 INVITE
User-Agent: voip.ms
Date: Tue, 07 Feb 2017 21:12:15 GMT
Remote-Party-ID: "OTTAWA, ON" <sip:6139876543@67.205.74.187>;party=calling;privacy=off;screen=no
Content-Type: application/sdp
Content-Length: 223
v=0
o=root 877975709 877975709 IN IP4 67.205.74.187
s=voip.ms
c=IN IP4 67.205.74.187
t=0 0
m=audio 19694 RTP/AVP 0 101
a=rtpmap:0 PCMU/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=ptime:20
a=sendrecv
010406: Feb  7 16:11:41.433: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=6131234567, Called Number=6131234567, Peer Info Type=DIALPEER_INFO_SPEECH
010407: Feb  7 16:11:41.433: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Match Rule=DP_MATCH_DEST; Called Number=6131234567
010408: Feb  7 16:11:41.433: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Dial String=6131234567, Expanded String=6131234567, Calling Number=6131234567T
   Timeout=TRUE, Is Incoming=FALSE, Peer Info Type=DIALPEER_INFO_SPEECH
010409: Feb  7 16:11:41.433: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
   OutboundSearch=TRUE, Peer Info Type=DIALPEER_INFO_SPEECH, Current Peer(Tag=1800,Peer Info Type=DIALPEER_INFO_FAX)
010410: Feb  7 16:11:41.433: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
   Result=Success(0); Outgoing Dial-peer=20012 Is Matched
010411: Feb  7 16:11:41.433: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Result=Success(0) after DP_MATCH_DEST
010412: Feb  7 16:11:41.433: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
   dialstring=6131234567, saf_enabled=1, saf_dndb_lookup=1, dp_result=0
010413: Feb  7 16:11:41.433: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
   List of Matched Outgoing Dial-peer(s):
     1: Dial-peer Tag=20012
010414: Feb  7 16:11:41.437: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
To: <sip:6131234567@70.11.54.125>;tag=3FC274C-14C2
Date: Tue, 07 Feb 2017 21:11:41 GMT
CSeq: 102 INVITE
Content-Length: 0
010415: Feb  7 16:11:41.533: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 102 INVITE
Content-Length: 0
010416: Feb  7 16:11:41.537: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:6131234567@70.11.54.125 SIP/2.0
Max-Forwards: 70
CSeq: 102 ACK
User-Agent: voip.ms
Content-Length: 0
010417: Feb  7 16:11:59.033: %SEC-6-IPACCESSLOGP: list 105 denied udp 17.173.254.223(16387) -> 169.1.1.1(60025), 11 packets
010418: Feb  7 16:12:05.409: //3072/000000000000/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 192.168.2.13:5060;branch=z9hG4bK143B9FE
Date: Tue, 07 Feb 2017 21:12:05 GMT
Call-ID: E94FCED8-ECB011E6-841BEC0A-4794616F@montreal2.voip.ms
Max-Forwards: 70
CSeq: 101 OPTIONS
Content-Length: 0
010419: Feb  7 16:12:05.418: //3072/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 192.168.2.13:5060;branch=z9hG4bK143B9FE;received=70.11.54.125;rport=60110
To: <sip:montreal2.voip.ms>;tag=as33c892c1
CSeq: 101 OPTIONS
Server: voip.ms
Content-Length: 0
010420: Feb  7 16:12:09.998: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
REGISTER sip:montreal2.voip.ms:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.2.13:5060;branch=z9hG4bK143CD54
From: <sip:123456_line@montreal2.voip.ms>;tag=3FC96E0-C9A
To: <sip:123456_line@montreal2.voip.ms>
Date: Tue, 07 Feb 2017 21:12:09 GMT
Call-ID: 3F49BED6-ECAC11E6-83F3EC0A-4794616F
Max-Forwards: 70
Timestamp: 1486501929
CSeq: 55 REGISTER
Contact: <sip:123456_line@192.168.2.13:5060>
Expires:  60
Supported: path
Content-Length: 0
010421: Feb  7 16:12:10.006: //3073/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 401 Unauthorized
Via: SIP/2.0/UDP 192.168.2.13:5060;branch=z9hG4bK143CD54;received=70.11.54.125;rport=60110
To: <sip:123456_line@montreal2.voip.ms>;tag=as3e14e196
CSeq: 55 REGISTER
Server: voip.ms
WWW-Authenticate: Digest algorithm=MD5, realm="montreal2.voip.ms", nonce="0b96b19c"
Content-Length: 0
010422: Feb  7 16:12:10.010: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 192.168.2.13:5060;branch=z9hG4bK143D22DD
Date: Tue, 07 Feb 2017 21:12:10 GMT
Max-Forwards: 70
Timestamp: 1486501930
CSeq: 56 REGISTER
Expires: 60
Authorization: Digest username="123456_line",realm="montreal2.voip.ms",uri="sip:montreal2.voip.ms:5060",response="5a7ad20ce76a778a823851ccbebaa962",nonce="0b96b19c",algorithm=MD5
Content-Length: 0
010423: Feb  7 16:12:10.018: //3073/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 192.168.2.13:5060;branch=z9hG4bK143D22DD;received=70.11.54.125;rport=60110
CSeq: 56 REGISTER
Server: voip.ms
Expires: 60
Contact: <sip:123456_line@192.168.2.13:5060>;expires=60
Date: Tue, 07 Feb 2017 21:12:44 GMT
Content-Length: 0
010424: Feb  7 16:12:11.706: //6/850BEB228005/DSM:(50/0/9):-1/dsp_stream_mgr_get_levels_sync: .
010425: Feb  7 16:12:11.706: //6/850BEB228005/DSPAPI/[]/dsp_query_info:
    Request ID=6, Reset Flag=FALSE Q:TX RX Levels
010426: Feb  7 16:12:11.706: //6/850BEB228005/DSPAPI/[]/dsp_tx_stats:
    Request ID=6, Packets: Voice=0, Signaling=0, ComfortNoise=0
    TX duration=0(ms): Voice=0(ms), FAX=0(ms)
010427: Feb  7 16:12:11.706: //6/850BEB228005/DSPAPI/[]/dsp_rx_stats:
    Request ID=6, Packets: Voice=0, Signalling=0, ComfortNoise=0
    RX duration=0(ms): Voice=0(ms), FAX=0(ms)
    Packets: Bad Sequence=0, Bad Protocol=0, Late=0, Early=0
010428: Feb  7 16:12:11.706: //6/850BEB228005/DSPAPI/[]/dsp_level_stats:
    Request ID=6, TX: power=0.0(dBm0), mean=0.0(linear PCM), RX: power=0.0(dBm0), mean=0.0(linear PCM)
    Background Noise=0.0(dBm0), ERL level=0.0(dB)
    ACOM level=0.0(dB), Current TX act=2, Current RX act=2
    Reflector locations: 19586(ms) 12361(ms) 513(ms), MAX reflector=4(ms)
    2 ECAN control words: 670 7562, ECAN Version=6C69.63A4(na)
010429: Feb  7 16:12:11.706: //6/850BEB228005/DSM:(50/0/9):-1/dsmp_dsmapi_stats_cb: .
010430: Feb  7 16:12:11.706: //7/850BEB228005/DSM:(0/4/0):-1/dsp_stream_mgr_get_levels_sync: .
010431: Feb  7 16:12:11.706: //7/850BEB228005/DSPAPI/[0/1:1]/dsp_query_info:
010432: Feb  7 16:12:11.710: //7/850BEB228005/DSPAPI/[0/1:1]/dsp_tx_stats:
    Request ID=6, Packets: Voice=3340182, Signaling=0, ComfortNoise=0
    TX duration=66803650(ms): Voice=66803650(ms), FAX=0(ms)
010433: Feb  7 16:12:11.710: //7/850BEB228005/DSPAPI/[0/1:1]/dsp_rx_stats:
    RX duration=66803650(ms): Voice=0(ms), FAX=0(ms)
010434: Feb  7 16:12:11.710: //7/850BEB228005/DSPAPI/[0/1:1]/dsp_level_stats:
So here is the host portion of the request URI (70.11.54.125). Like I said earlier, do you have this IP on the UC520? If you dont, then your NAT is not working correctly. The gateway will not process any request for an IP that is not its own
Received:
