I would like to hang a HP wireless access point off port fa0/1/8 and deliver PoE to it.
The A/P is to be assigned 192.168.100.252.
Currently fa0/0 has the ip address 192.168.100.251/24.
Ports fa0/1/0 to fa0/1/7 are in voice vlan 100.
Appropriate section of the config below:
interface Loopback0
description $FW_INSIDE$
ip address 10.1.10.2 255.255.255.252
ip virtual-reassembly
interface FastEthernet0/0
description $FW_OUTSIDE$
ip address 192.168.100.251 255.255.255.0
ip nat outside
duplex auto
speed auto
crypto map IPSEC-TRAFFIC
interface Integrated-Service-Engine0/0
ip unnumbered Loopback0
ip nat inside
service-module ip address 10.1.10.1 255.255.255.252
service-module ip default-gateway 10.1.10.2
interface FastEthernet0/1/0
switchport voice vlan 100
macro description cisco-phone
interface FastEthernet0/1/1
interface FastEthernet0/1/2
interface FastEthernet0/1/3
interface FastEthernet0/1/4
interface FastEthernet0/1/5
interface FastEthernet0/1/6
interface FastEthernet0/1/7
interface FastEthernet0/1/8
switchport mode trunk
macro description HP-access-point
interface Vlan1
ip address 192.168.10.1 255.255.255.0
ip nat inside
interface Vlan100
ip address 10.1.1.1 255.255.255.0
ip nat inside
Brendon.
What exactly do you need help with? Is it not working just set up as a trunk? You will probably get better input over at the LAN Switching section.
