04-06-2011 11:52 AM - edited 03-16-2019 04:22 AM
I'm sure I'm just ignorant to something here but when I browse to the UC540 in the download section there is no place for me to download a new IOS version. If I select the UC520 the IOS section is there. The current version I am on is 15.0(1)XA and I would just like to look through the release notes to see if there is any reason to upgrade.
Solved! Go to Solution.
04-08-2011 05:42 AM
Hi Jason,
I believe they moved to their own site
https://supportforums.cisco.com/docs/DOC-9829
Cheers!
Rob
Edit: I didn't notice the reply from my friend Paolo (+5 "P")
04-08-2011 05:25 AM
Hmmm, I must be pretty far off. Any help at all?
04-08-2011 05:37 AM
"Unfortunately", Cisco decided that we should not be able to download IOS only for the UC5x0 where x = 4 or 6 but not 2. You can only download huge packages that contains all but the kitchen sink.
04-08-2011 06:57 AM
Where can I find these packs? I saw Unified Communications Software Packs but it doesn't contain any IOS images or change logs.
I guess the real question I should be asking is where can I download updated IOS or get the release notes to review?
Thanks for your help.
04-08-2011 05:42 AM
Hi Jason,
Cheers!
Rob
04-08-2011 07:26 AM
04-08-2011 07:41 AM
Ha, I tried to go to the site at first and I just entered in my login info wrong, got denied so I thought it might be a bad link. It works now, thanks for the info.
