06-12-2013 09:33 AM - edited 03-16-2019 05:50 PM
Hi, I have a problem with a UC540, i can outgoings call with the sip trunk but it´s imposible incoming call.
This is debug ccsip messages
Syslog logging: enabled (0 messages dropped, 3 messages rate-limited, 0 flushes, 0 overruns, xml disabled, filtering disabled)
No Active Message Discriminator.
No Inactive Message Discriminator.
Console logging: disabled
Monitor logging: disabled
Buffer logging: level debugging, 22 messages logged, xml disabled,
filtering disabled
Exception Logging: size (4096 bytes)
Count and timestamp logging messages: disabled
Persistent logging: disabled
No active filter modules.
Trap logging: level informational, 304 message lines logged
Logging Source-Interface: VRF Name:
Log Buffer (5000000 bytes):
000290: Jun 5 18:33:35.231: %SYS-5-CONFIG_I: Configured from http by cisco on 192.168.10.66
000291: Jun 5 18:33:35.371: %SYS-5-CONFIG_I: Configured from http by cisco on 192.168.10.66
000292: Jun 5 18:33:40.151: %SEC-6-IPACCESSLOGP: list 104 denied tcp 88.26.221.114(15183) -> 192.168.0.80(443), 1 packet
000293: Jun 5 18:33:41.419: %SEC-6-IPACCESSLOGP: list 104 denied tcp 77.229.64.164(49627) -> 192.168.0.80(443), 1 packet
000294: Jun 5 18:33:42.683: %SEC-6-IPACCESSLOGP: list 104 denied tcp 84.127.226.179(18805) -> 192.168.0.80(443), 1 packet
000295: Jun 5 18:33:43.947: %SEC-6-IPACCESSLOGP: list 104 denied tcp 77.229.64.164(13182) -> 192.168.0.80(443), 1 packet
000296: Jun 5 18:33:49.491: %SEC-6-IPACCESSLOGRL: access-list logging rate-limited or missed 119 packets
000297: Jun 5 18:33:53.183: %SEC-6-IPACCESSLOGP: list 104 denied tcp 88.26.221.114(15192) -> 192.168.0.80(443), 1 packet
000298: Jun 5 18:33:54.455: %SEC-6-IPACCESSLOGP: list 104 denied tcp 77.229.64.164(49629) -> 192.168.0.80(443), 1 packet
000299: Jun 5 18:33:55.763: %SEC-6-IPACCESSLOGP: list 104 denied tcp 84.127.226.179(18818) -> 192.168.0.80(443), 1 packet
000300: Jun 5 18:33:56.987: %SEC-6-IPACCESSLOGP: list 104 denied tcp 77.229.64.164(13184) -> 192.168.0.80(443), 1 packet
000301: Jun 5 18:34:04.543: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:856924825@62.43.206.102:56214 SIP/2.0
Via: SIP/2.0/UDP 94.23.83.177:5060;branch=z9hG4bK55dcb427;rport
Max-Forwards: 70
From: "956059747" <sip:956059747@94.23.83.177>;tag=as15ae1fa9
To: <sip:856924825@62.43.206.102:56214>
Contact: <sip:956059747@94.23.83.177:5060>
Call-ID: 62aab4b526eb4e397b659c2766a1206f@94.23.83.177:5060
CSeq: 102 INVITE
User-Agent: VozGlobal
Date: Wed, 05 Jun 2013 16:31:40 GMT
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY, INFO, PUBLISH
Supported: replaces, timer
Remote-Party-ID: "956059747" <sip:956059747@94.23.83.177>;party=calling;privacy=off;screen=no
Content-Type: application/sdp
Content-Length: 272
v=0
o=root 1516626963 1516626963 IN IP4 94.23.83.177
s=VozGlobal
c=IN IP4 94.23.83.177
t=0 0
m=audio 14058 RTP/AVP 18 8 101
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=rtpmap:8 PCMA/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=ptime:20
a=sendrecv
000302: Jun 5 18:34:04.547: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 400 Bad Request - 'Invalid Host'
To: <sip:856924825@62.43.206.102:56214>;tag=8F9F8-2485
Date: Wed, 05 Jun 2013 16:34:04 GMT
CSeq: 102 INVITE
Allow-Events: telephone-event
Reason: Q.850;cause=100
Server: Cisco-SIPGateway/IOS-12.x
Content-Length: 0
000303: Jun 5 18:34:04.631: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:856924825@62.43.206.102:56214 SIP/2.0
Max-Forwards: 70
CSeq: 102 ACK
Content-Length: 0
000304: Jun 5 18:34:06.263: %SEC-6-IPACCESSLOGP: list 104 denied tcp 88.26.221.114(15203) -> 192.168.0.80(443), 1 packet
000305: Jun 5 18:34:07.463: %SEC-6-IPACCESSLOGP: list 104 denied tcp 77.229.64.164(49631) -> 192.168.0.80(443), 1 packet
000306: Jun 5 18:34:08.791: %SEC-6-IPACCESSLOGP: list 104 denied tcp 84.127.226.179(18828) -> 192.168.0.80(443), 1 packet
000307: Jun 5 18:34:10.031: %SEC-6-IPACCESSLOGP: list 104 denied tcp 77.229.64.164(13187) -> 192.168.0.80(443), 1 packet
Thanks,.
Solved! Go to Solution.
06-12-2013 09:37 AM
The NAT device that you use do not work for SIP.
You can use a cisco router for NAT, or give UC500 a public IP address.
06-12-2013 09:37 AM
06-12-2013 09:54 AM
Hi Paolo,
I have the UC540 direct to the router, i don´t understand your solution, how i can give a public IP address to UC540?
thanks.
06-12-2013 10:28 AM
The error you are getting suggest that the sip traffic has been sent to an IP address that doesnt exist on your uc520. The ip address 62.43.206.102 is not configured on your UC520. That means as Paolo suggsted your NAT configuration is not working. You need to fix that.
Sent:
From: "956059747" <956059747>;tag=as15ae1fa9956059747>
To: <856924825>;tag=8F9F8-2485856924825>
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
06-12-2013 10:31 AM
OK, but it´s possible with the UC540 nat?
thanks
06-12-2013 10:51 AM
aokanlawon wrote:
No, I dont think your UC540 can do NAT for sip traffic.
Absolutely it can. It is a Cisco router after all.
06-12-2013 10:55 AM
Paolo I said that because it looks like most people use ASA to do the NAT when UC5XX series are deployed. I may be wrong. Thanks for correcting that idea
06-12-2013 11:05 AM
Nothign wrong with that, But I have deployed tens of CMEs and UC500s without ever using ASA, always had ecellent results technically, and economically without compromising any security.
06-12-2013 10:51 AM
Set the ISP router in bridge mode. Configure UC500 WAN port as it was ISP router.
06-12-2013 02:39 PM
Thank you very much for yours help, it will try it and I tell you.
06-13-2013 05:01 AM
My configuration is this:
UC540 LAN 192.168.10.1
UC540 WAN 192.168.0.80
PUBLIC IP:62.43.206.102 Cisco EPC3825 EuroDocsis 3.0 Gateway
I need you said me how i can configure in UC540 Nat pool and Nat static Mapping.
Thank you very much for yours help.
06-13-2013 06:42 AM
As above, configure Fa0/0 for public IP as per ISP instrucions.
