UC540 reverts to older config on hard shutdown
Scott Hanson
Level 3
Level 3
All,
I have a UC540 at a site that if it loses power and goes down hard when it comes back up it has reverted to an older configuration.  I don't see anywhere to list a backup of the config, I save the run to start and that's it.  It seems not to happen if I issue a reload command, only on a power failure.  Anyone seen this or know where I might start looking for the cause?
Thanks.  Replies rated.
Maybe this can point you in a direction
https://supportforums.cisco.com/thread/2135073
Best Regards
Thanks Hermanus!  I think that last entry on the post should fix me up quite nicely
