uc540 with ip communictor
zeuscyril
Level 4
Level 4
                  hi all,
i am having 2 uc540 devices in different places.
there is site to site vpn between these two boxes for multisite configuration and also remote vpn also configured on bot the devices.
my issue is i am using ip communicator for remote user , when i connect to vpn client of branch A the ip communicator is working , when i connect to BranchB it is not registering to that branch . it is still looking for branch A TFTP server ,  i am manully changing the TFTP server ip on the ipcommunicator.
no luck and i tried with different mac address for different sites also the same.
is there any possible way to configure 2 different extension for different system with single ip communicator.
thanks
cyril
paolo bevilacqua
When a phone or CIPC looks for another TFTP, that means the configured TFTP address is not responding, and is using a previous one as backup. So check your VPN connectivity.
You cannot register CIPC to two different systems.
i cannot register single CIPC software in single pc to 2 different uc 540 devices?
there is no other solution for this.
zeuscyril
Level 4
Level 4
Vpn is fine . I can reach the system through vpn.
Sent from Cisco Technical Support Android App
