06-30-2012 10:37 PM - edited 03-16-2019 11:56 AM
hi all,
i am having 2 uc540 devices in different places.
there is site to site vpn between these two boxes for multisite configuration and also remote vpn also configured on bot the devices.
my issue is i am using ip communicator for remote user , when i connect to vpn client of branch A the ip communicator is working , when i connect to BranchB it is not registering to that branch . it is still looking for branch A TFTP server , i am manully changing the TFTP server ip on the ipcommunicator.
no luck and i tried with different mac address for different sites also the same.
is there any possible way to configure 2 different extension for different system with single ip communicator.
thanks
cyril
07-01-2012 02:31 AM
When a phone or CIPC looks for another TFTP, that means the configured TFTP address is not responding, and is using a previous one as backup. So check your VPN connectivity.
You cannot register CIPC to two different systems.
07-08-2012 05:35 AM
i cannot register single CIPC software in single pc to 2 different uc 540 devices?
there is no other solution for this.
07-01-2012 07:19 AM
Vpn is fine . I can reach the system through vpn.
Sent from Cisco Technical Support Android App
