10-16-2014 02:17 PM - edited 03-17-2019 12:35 AM
I have a UC560 system with 4 digit extensions. The outbound caller ID over our T1 PRI is only showing 4 digits. I checked with TelePacific (our provider) and they confirmed they are only receiving 4. They have also confirmed they will accept any numbers I send. I have gone into the outgoing dial plan and made sure that the default Caller ID is the full 10 digit number. I have also tried adding explicit caller ID overrides in the lower half of the screen. I have even tried to make the default caller ID a 4 digit number like 5900 which is the main line, but still every call transmits its 4 digit extension. I added a Caller ID per call block code on the outbound page and when I use that code while placing an outside call the caller ID is blocked so definitely the calls are being handled in some form. I have changed the PSTN number on one extension to be the full 10 digits and still it only sends 4 on the outbound,
Any help would be greatly appreciated.
Thanks.
10-16-2014 11:57 PM
pls post , deb isdn q931
and sh run
03-02-2015 07:49 AM
I experienced the same trouble on a call manager this morning.
Call manager 9.1
MGCP gateway with a PRI
The fix was:
-> Go the gateway
-> click on the PRI
-> Scroll down to Call routing information - Outbound calls
-> With in the "Caller ID DN" parameter, enter example (222333XXXX), X being the wildcard for your ext's.
-> click save and apply
