Showing results forĀ
Search instead forĀ
Did you mean:Ā
UC560 REMOTE PHONES
gonzalo-castro
Hi All,
could you please tell me what are the options  to connect Remote phones (1 per site) to the Central UC560? I am at the design step
What do I need for  the remote sites?
REGARDS
GCA
paolo bevilacqua
Router to create VPN. Better if these, or the switches, have PoE.
paolo bevilacqua
Now I got that the 7945 can connect by VPN with an ASA to the CME8.x
What I donĀ“t know is it is enough with the ASA Essential VPN License :
ASA-AC-E5505
Anny Connect Essential vpn license    ASA 5505 25 user
Or if it is nescesary the premium one:
ASA5500-SSL-25
ASA   5500 SSL VPN 25 Premium User License
I Appreciate your help,
regards
You would need the SSL VPN licenses.
Even better, use a router instead of ASA, and need no licenses.
Note: doing phone VPN is very ver complicated and poorly documented. Better to place a small router at the remote site instead.
