02-02-2016 05:42 PM - edited 03-17-2019 05:43 AM
I have a UC560 that can't communicate with the CUE. When I try to execute 'service-m i0/0 se' I get this...
UC560#service-module i0/0 session
Trying 10.1.10.2, 2002 ...
% Destination unreachable; gateway or host down
I then checked my interfaces and I see that VLAN90 and VLAN100 status is up but protocol is down. I went into the VLAN config in CCA, VLAN 1 shows up but 90 and 100 do not. What can I do to turn these up?
02-03-2016 03:10 AM
Are these vlans on the service-module I would have thought they were in standard running config on a UC560 not on the telephony unity module ?
There's 2 reasons a svi vlan can go like that
1 there is not active layer 2 port in up/up status for the layer 3 vlan
or
2 There is not stop instance for that vlan
You can stop session sometimes they lock up on module and clear it can fix access , once its been configured before hand
From the Host-Router CLI
2. service-module ism 0/0 status
or
service-module sm slot/0 status
3. service-module ism 0/0 session
or
service-module sm slot/0 session
From the Service-Module Interface
4. Perform configuration or other procedures.
6. service-module ism 0/0 session clear
or
service-module sm slot/0 session clear
02-03-2016 10:27 AM
When I run a service-module ism 0/0 status this is what I get...
UC560#service-module integrated-Service-Engine 0/0 status
Service Module is Cisco Integrated-Service-Engine0/0
Service Module supports session via TTY line 2
Service Module is failed
Service Module heartbeat-reset is enabled
Service Module status is not available
If I try the service-module ism 0/0 session I just get the Destination unreachable...
UC560#service-module integrated-Service-Engine 0/0 session
02-03-2016 10:51 AM
That does not look good --Service Module is failed
Have you tried reseating the module it could have failed completely in hardware but reseating them like any module if it just got stuck somehow can help
does it give an option instead of session try the reload to reboot it the module too
