UCCX 5.0.2 with TAPS (CallManager 7x)
Jason Aarons
Level 6
Level 6
Customer is using CallManager 7.1 with off-box CRS 5.0.2 MCS-7845 server for TAPS (Tool for Auto-Registered Phones Support). Currently I can have up to 5 phones connecting running the TAPS .aef script.
What is the UCCX license part number to increase the number of ports for TAPS?
We currently have 150IVR ports and 5 Agent Licenses? Does TAPS use Agent Licenses?
Or maybe I don't need licenses and that that in AppAdmin on UCCX under Trigger and/or Media Termination Dialog Group I need to increase the number ?
hansolo107
You should be able to increase the port count by modifying your Unified CM Telephony Call Control Group. Go to Subsystems > Unified CM Telephony > Unified CM Telephony Call Control Group and increase the "Number of CTI Ports". UCCX will create the ports for you in CUCM.
Tommer Catlin
You cant use UCCX 5.x with CUCM 7.x You have to upgrade UCCX to 7.0.
