05-29-2012 01:11 PM - edited 03-16-2019 11:24 AM
I have a UCCX 7 cluster ( pub and sub) installed on MCS servers we are migrating to UCS and installting UCCX 8.5
I have taken bakup from the UCCX 7 using PUT tool and upgraded the call manager to 8.5
I installed the UCCX 8.5 publisher on the UCS and tried to restore the backup i took from the old cluster.
but it gives error at phase 1
the error is : " failed : importing hibernate data operation "
any ideas.
thanks
05-29-2012 01:35 PM
Just googled for this error and got quite few finds, some of them:
http://docwiki.cisco.com/wiki/FAILED_:_Cisco_Unified_CCX_agent_desktop_configuration_data_migration
http://docwiki.cisco.com/wiki/Failure_during_restore_operation_of_Windows_to_Linux_upgrade
https://supportforums.cisco.com/thread/2080004
HTH,
Chris
05-29-2012 01:44 PM
Thx chris,
i have also found these links but they are not usefull i have taken the backup three times and every restore the same error
05-29-2012 07:17 PM
Hi Mohamed,
What is the exact version of UCCX 7.0, and what SR?
I would suggest to upgrade it to the latest SR, and use its specific PUT tool to backup and try restoring it.
Hope it helps.
Anand
Pls rate helpful posts !!
05-29-2012 10:37 PM
Hi Anand,
I have now UCCX version 7.0.1SR05_Build504, which is compatible with 8.5.1.
So any ideas ?
Mohamed
06-27-2012 12:36 AM
Having the exact same problem with same versions.
Has anybody found a solution?
regards,
Mike.
12-01-2012 01:50 AM
I found this problem too! Anyone know how to solving please share to us. T T
12-01-2012 02:30 AM
Make sure you have the version of PUT that matches the version of UCCX you are migrating to.
e.g. If migrating to UCCX 8.5.1SU3, make PUT is that version and not 8.5.1 (no SU or SU1 etc.).
