09-11-2015 09:41 AM - edited 03-17-2019 04:17 AM
I have question about Cisco Finesse) login. Any advice would be greatly appreciated---
we have small call center (25 agents) and this how we are thinking to configure them-
half of the agents-line 1 on their phone would be 1XXX which is their IPCC extension. They will use the same ext to login to finesse.
Other half-will have device profile created. They will actually go to a phone, login to the phone with 'generic' login id (for everyone in this team) and pick their profile on the phone from the list. This team only cover the help desk whenever help desk agents need to go for a meeting etc.
How can I achieve this? What do I need to do to get this working?
environment-uccx 10.5 and Finesse
Solved! Go to Solution.
09-14-2015 06:15 AM
Step 3 is where you already have users in the CCM (LDAP Synch and Auth) and you already have phones in the system (BAT), however the users (End Users) do not have it under their Controlled Devices and EM Device Profiles.
Please let us know if you want any more details
regards
09-11-2015 09:59 AM
Hi Gary,
Just making sure that you are asking the configuration about Users / Device Profiles and BAT associated with them and not anything else (e.g. CCX Integration, Scripting etc)
09-11-2015 11:01 AM
That is correct....mainly-configuration of phones and users.
09-11-2015 11:54 AM
I did a recent implementation and based on my recent experience this is what I will recommend:
1. Make the CCM use LDAP Authentication and Synchronization
2. Get the AD Admin to give you the LDAP user ID and Extension Numbers
3. Use the above info to create UDP Profiles and Associate them with the Users (LDAP Synched) and Add Phones, as well as associate the Phones with the respective users
4. Once all the phones and users are associated (CTI Control and EM Profile association), make sure you Update the Users for the IPCC Extension (although it is NO where written, the step is to make sure that in this BAT file has Extension as "DN in PT" format else it wont update the IPCC Extension and the main Ext
This should be enough, please feel free to let us know if you have any other questions.
09-11-2015 12:01 PM
Thanks so much for the information----
Can you elaborate on step 3....I get the part creating profiles...how do I associate them with users and phones? Where do I need to go and do this part? Thanks
09-14-2015 06:15 AM
regards
09-14-2015 07:32 AM
Thanks so much for the info. I give it a try.
