uccx csq max calls
Hi all.
Is there any way to limit to a fixed number of calls hitting a particular CSQ with shared agents?
More in detail..
I have eg 2 csq containing same agents and i wonder if is possible to fix a maximum number of calls for each CSQ. (connected+queued).
I tried with get reporting statistic step, but it doesn't fit with my case.
Any suggestion would be appreciated.
Thanks for your help
Carlo
Please rate all helpful posts "The more you help the more you learn"
Unfortunately you cannot get number of calls being currently handled from the script and I doubt it is actually stored anywhere in DB to look it up, you can look for current calls waiting in specific queue only.
Chris
anchoudh
Level 9
Level 9
Hi Carlo,
If you have two different applications, than you can limit the number of calls hitting these two applications by,
1. Providing Number of instances at the Route point\application level
2. Also by creating the specific number of CTI ports in the Call Control Group associated with the Route point.
Hope this helps.
Anand
Pls rate helpful posts !!
Hi Anand.
Thanks for your reply.
Unfortunately at application or trigger level limiting max sessions doesn't take care about connected calls so the desired maximum calls value would not be respected.
Any chance to achieve this at script level?
Thank again for your help
Carlo
Chris
that's what i suspected.
Thanks Chris
Carlo
