Good Day,
Can anybody help me? The question is: can I create Directory Number without linking with IP Phone, and add mobility number to this DN?
Thanks for help.
Solved! Go to Solution.
Not sure whether i got your question or not. But you can create a dummy DN on CUCM and associate it to the remote destination profile(RDP) and configure Unified mobility. By adding mobility number to this DN, did you mean associating with an RD(remote destination)? If so, its possible.
Check this doc, somewhat related to what you want
https://supportforums.cisco.com/docs/DOC-14629
Nitesh
PS:Pl rate helpful posts
Nitesh
Yes, you got it right! Thank you, it's solved my problem. You helped me so much. Thank you.
With Regards,
Anton Vereskun
