10-17-2012 12:21 PM - edited 03-16-2019 01:44 PM
Does anyone know for certain what physical interfaces that UCM 8.x supports to External MOH sources? In CCM 4.x we used to use Griffin IMIC USB adapters to connect CCM to external MOH sources. From what I am reading and seeing these will not work on UCM linux platform. The other question is how would you connect an External MOH source to a Virtualized UCM server ??
Thanks in advance,
Tony C
10-17-2012 06:01 PM
You still can use the USB MOH adapter on linux appliances BUT ONLY on MCS servers, if you're doing UC on UCS there's no way to do such thing. Closest thing is live-feed + SRST as MOH with CUCM
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
10-17-2012 06:08 PM
Take a look at Mr. Bell's summarization of the options here:
http://www.netcraftsmen.net/resources/blogs/live-stream-music-on-hold-and-cisco-uc-on-ucs.html
Please remember to rate helpful responses and identify helpful or correct answers.
